Question about Ovens
Continious noise is coming from the clock on our oven.
We own a whirlpool electric built-in self cleaning single oven model number RB160PXL-2. The clock is making a countious loud running noise that we can not get to stop. It has gone on for about 24 hours now. We tried to play with the clock and the timers and this does nothing but change the pitch of the sound. We tried to turn the circuit breaker on and off but it just starts right up again when the power is returned. The oven seems to be working fine, it will heat up but we have not ''used'' it since the noise began. Please help us to silence the noise.
  • Anonymous Apr 18, 2009
    We also have the same problem at home. Sadly, the parts for our oven cannot be bought anymore. I would recommending disconnecting the clock from the oven. Good luck!
aborcass
  • 2651 Answers
SOURCE: Wont' heat in broil or bake
check incoming electric first, pull it out and gain access to main wire terminal, With multimeter set to at least 250v AC , check your power across the wiring as such. black to white (110v), red to white(110v) and then black to red 230v. if that ok ok turn, then start ckin elements for continuty also there might be a thermostat( usually an 1 in. round component with 2 wires located right inbetween the elements that has gone bad, will show no continuity. ck that before electronic control the fact that its clickin sounds like the relays are workin properly
Posted on Feb 23, 2008
SOURCE: GE Profile JGB97 Self Cleaning Oven Controls won't work
only the temp. down button won't work on my ge profile oven
Posted on Oct 01, 2008
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
  • 41 Answers
SOURCE: oven won't heat
There is a design problem with certain model Whirlpool ranges where the thermal fuse blows during self-cleaning (auto-clean). This may be because of inadequate insulation, causing the outer panel to overheat. When the thermal fuse is replaced, the range will work, but it will blow the next time auto-clean is done. To safely work around the problem, the thermal fuse may be replaced with a thermostat, which will reset itself once the oven has partially cooled off. If the part number of the thermal fuse is 9759243, it will blow at 120 deg C (248 deg F). This can be replaced to a Selco Part# SES-L250 thermostat. The terminals are perpendicular (90 degress), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Selco part# SES-L250 specs:
Surface Mount
3/4 in. disc
120/240 VAC
25 A
SPDT
open on-rise (normally closed)
open (cut-out): 250 deg F
close (cut-in): 220 deg F
temperature differential: 40 deg F
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/surface-mount-automatic-reset-open-on-rise/pn-5113?&seo=110
Available: Selco distributors: http://www.selcoproducts.com/distributors.php
and online at
Allied Electronics http://www.alliedelec.com
If the Selco SES-L250 'surface mount' thermostat is not available, an 'airstream type' thermostat can be used with a few differences:
1) I recommend to replace it to a 240 or 230 deg F thermostat. The reason for the lower cut-out temperature is that an 'airstream mount' thermostat will not be flush with the back panel, as is the original 250 deg F 'surface mount' one, so it may cut-out at a higher (unsafe) temperature.
2) I recommend to add Heat-sink compound between the thermostat and the sheet metal. This is used for computer processors and is available at computer and electronic component stores.
3) An 'airstream type' thermostat is thicker than the original 'surface mount' one, so longer screws will have to be obtained. The sheet metal tabs on the thermostat will bend slightly when installing.
4) The terminals are perpendicular (90 degress), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
Recommended 'airstream type' thermostats:
Supco L240
Info: http://www.supco.com/images/pdfs/2009%20HVAC%20Caralog/2009%20Catalog%20for%20Web2.pdf
Available: http://www.appliancefactoryparts.com/applianceshvac/supco/crossref/thermostats2.html
Selco SE-L240
Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/ts-3-4-disc-se-series-airstream-mount-open-on-rise/pn-5096?&seo=110
White-Rodgers 3L01-230
Info: http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0092.pdf
General Electric LS2-240
Posted on Nov 03, 2009
  • 1891 Answers
SOURCE: MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Posted on Dec 09, 2009
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
I used the self cleaning feature once on a built in oven. After that it doesn't work. Why?
I used the self clean feature on mine and found out, to late, that it gets so hot that it burns out some of the electrical components. I suggest NEVER use the self clean feature
May 19, 2010 | Whirlpool RBS245PDS Electric Single Oven
My whirlpool accubake built in oven has error code E1F1 due to a power failure. How do I fix this?
It is always a good idea to include both model and serial numbers when requesting help on any appliance... but try...
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
May 06, 2009 | Whirlpool RBS305PDS Electric Single Oven
Self Cleaning Oven help
It should run with you setting anything but clean. You can obtain a copy of the owners manual from the maytag site or by googling your maytag appliance model number.
Dec 24, 2008 | Maytag 24" Built-In Single Electric Wall...
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
WHIRLPOOL OVEN
have you checked your in coming power the clock will work on 110 but it takes 220 for full function zzsbolt yours does sounds like a thermal fuse
Jan 18, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
98 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
