Question about Toshiba 51HX83 51" Rear Projection HDTV-Ready Television
How do I connect my playstation 3 hdmi to toshiba 51hx83
2 Suggested Answers
SOURCE: sound is out for all inputs on Toshiba 51HX83
There is a switch on the back of the TV for center input. Make sure you have this set to OFF.
Posted on Dec 28, 2008
I have sound on my TV from the PS3 connection via HDMI, but no display...
From stand by (red LED) press and hold the power button, after about 5 seconds the PS3 will make a second beep. let go of the power button. This will reset your display settings.
if it asks you to display in HDMi and the screen remains black there after, just wait 30 seconds and it will default back to a lower resolution. This usually means that you have an HD READY TV which only supports 720. You can then cjange the display settings to what ever you like in the display settings menu.
Nov 23, 2014 | Sony Playstation 3 (PS3) Console
Toshiba 51HX83... what kind of lamp/bulbs and what size do i need to bring the brightness back?
your model doesnt have a lamp it has three CRT (Picture tubes) often just cleaning the rear mirror will restore brightness. If that doesnt do it then the CRT coolant may need to be replaced.
Aug 06, 2012 | Toshiba 51HX83 51" Rear Projection...
Can't seem to connect Playstation 3 to Toshiba 30HF84. No picture comes up on the HDMI screen of the tv. It's not the cable cause that worked fine on another tv.
ok kepp push on the power button on the ps3 its gonna beep ones then its gonna turn off than turn on again but keep pushing on the button its gonna beep ones then its gonna beep twice remove your fingur when it beep twice but make sure the hdmi connected its gonna ask you on the screen you want it to work with hdmi you gonna enter yes
Oct 17, 2010 | Toshiba 30HF84 30" TV
How do i change from 480i to 1080 on my Toshiba 52HM95 DLP im trying to hook up my playstation 3 with an HDMI cable but it wont switch over to 1080i
Most TVs choose the resolution based on the signal coming in. Be careful if you try and use 1080P. Not all TVs support it. 1080P is only on HDMI. set the playstation to 1080i before connection.
Some TVs and Playstation HDMI do not mix well due to software in the HDMI ports. Try RGB cables.
Apr 02, 2010 | Toshiba 52HM95 52" HDTV Projection...
PS3 no longer communicating with TV
The problem is with your PS3 itself.
If it's still under warranty, take it back.
May 30, 2009 | Sony Playstation 3 (PS3) Console
Ps3 hdmi cable with adapterto tv's rca's
Just use the regular AV cords. They are 480i using an HDMI to this and that isn't going to improve picture quality.
Mar 01, 2009 | Sony Playstation 3 (PS3) Console
Sound is out for all inputs on Toshiba 51HX83
Oct 12, 2008 | Toshiba 51HX83 51" Rear Projection...
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Toshiba 51HX83 51" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
