Question about Western Digital Computers & Internet
My WD external hard drive does'nt power up?
I plug the hard drive into the wall outlet and nothing happens, no light on the unit, no vibration, nothing internal. Western Digital My Book Essential 1 Terabyte (1TB) USB 2.0 Western Digital WD10000H1U-00
4 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: No power to my WD 1TB
If its under warranty then get it sent back.
If its not then almost any 3.5 " external sata enclosure will do so long as it has its own power supply. and if that supply is a wall-wart then should you pooch that, they are so easy to pick up and replace.
If you need quick access to the files remove the disk and fit it to a suitable computer.
If this information was useful please click
Posted on Aug 14, 2009
  • 10406 Answers
SOURCE: My Western Digital My Book
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
SOURCE: I HAD Western Digital My
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
Posted on May 24, 2011
Wd3200bmvs-11f9s0 not being recognised by any computer. do the jumper pulgs need to be bridged in any certain way
hello
do this and it should work : unplug the power and USB cords from the external WD drive
wait 20 seconds. plug the power cord into the drive (make sure the other end is plugged into the wall)
wait 20 seconds, plug the one end of the USB into the computer, and the other end into the WD external drive.
in a few seconds, your computer should see and activate the WD external drive.
thanks for using FIXYA -- please make sure to send me 4 thumbs up
May 10, 2011 | Western Digital Passport 320GB External...
500gb element external drive doesnt power up i plug it into the outlet light turns on then goes off and nothing
sounds like the power addapter internally of the externall hdd has failed its happend to a few of my customers and usaly i convert them into internall hard drives for them simply remove the outer casing and install as a second internall hard drive if you really want to get it fixed a local pc shop might be able to help however its only 59.99 for a new 1 tb (1000gb) from maplands just a thought hope this is of some use to you
Mar 17, 2010 | Western Digital Elements powered by WD 320...
WD ELEMENT DOESNT POWER UP. GREEN AND BLUE LIGHT FLASHES
Have you contacted WDE.. by email,or, phone? Seems like that the hard drive has had its bios info corrupted , due to possibly hooking it up to the pc(in the wrong order), or even, a power surge that you were not aware of... The Manufacturer can send you a link to upgrade/restore the harddrive bios...
Sep 01, 2009 | Western Digital Elements powered by WD 320...
WD Mybook I TB hard drive won't power up
It could be the power adapter but you'll need to verify that the wall outlet or power strip you have it plugged into actually has power. If it's a power strip make sure that it is turned on and has power and also plug the adapter into a different outlet on the strip as individual outlets can go bad or have a bad connection.
Jul 31, 2009 | Western Digital My Book Essential Edition...
WD 500 My Book Prem Ed will not power up
If it's less than a year old, call WD and get a replacement power brick and see if that works.
You could of course also buy a replacement and see if that works.
If the unit is not powering up, the HD inside is almost certainly good. Data recovery is trivial. All you have to do is open the case(hard part) and remove the hard drive. Find a desktop you can install it into and copy the data to a new external HD. If you don't have a a desktop available, you can buy a USB to SATA adapter with a power adapter for about $15-20 that will work well. If you're creative you could probably re-install one of these kits into the existing enclosure for a permanent fix.
Jul 26, 2009 | Computers & Internet
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
My WD5000H1-U00 will not start up when I plug power source in??!
Sounds like an internal switch or relay has failed. Not worth it to attempt repair. Were it me, I would open the case and recover the actual hard drive inside, it's probably still fine. For $25 you can buy a new external case to mount the drive in. This way you can save the data.
Jan 05, 2009 | Western Digital Caviar WD400AB 40 GB Hard...
External Hard drive
When I switched on my computer one day, Western Digital drivers were not found.
This works:
I have changed plug sockets, power strip to wall socket and now Western Digitals are now being detected.
Feb 13, 2008 | Computers & Internet
Computers & Internet Logo
233 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
