Question about KLH R5100 Receiver
We had this receiver for a little while and we just bought new speakers. (Bose) It worked for a little while and then it shuts itself off. We moved the speakers to another receiver and they work fine. The KHL receiver now only says check speaker. Any suggestions
  • 336 Answers
Probably a shorted amp. Turn it on with no speakers hooked up, if it still says check speakers,it will need service (output transistors and a couple of resistors) A few times I've seen them only need soldering of an emmittor resistor.
Posted on Jan 20, 2009
Hi, I bought a Bose acoustimass 16 - 6.1 channel, iam curious to know which receiver is suitable for that.
I would get a receiver that puts out a little less power than the speakers can handle. This will prevent you from blowing them by sending too much power to them, but will still send enough power to make them sound good.
An example would be, if you're speakers have a combined power of 500 watts get a receiver around 495 watts or a little less.
May 03, 2011 | Bose Acoustimass 16 System
I have four Bose 161 speakers and an Acoutismass 5 bass unit (original cubes are bad and replaced with the 161s). My Onkyo receiver started turning off and going into protect mode recently. Bought new...
you're going to need a ohm meter (good electrical testers have them) and make sure ohm ratings from speakers match the ratings for your receivers. Sounds like to much resistance for receiver(s)
Jan 06, 2011 | Bose 161 Rear Speaker
LG 47 External Audio Control
This is the only way a bose works
May 01, 2009 | LG 47 in. Flat-Panel LCD HDTV
Receiver Sr5200 shut down in 5.1 mode
chances are you have the volume too loud and the speaker wires are crossed.
all speaker wires need to be with the positive on the right and negative on the left if you have them anywhichway than it will work on low volume and not a very good sound.
look closely at the wires and they should have a red or so color on one side or the wire jacket itself will have a round side and a flat side
Apr 21, 2009 | Marantz SR-5200 Receiver
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
I bought a Denon AVR 3808 receiver. Bose says my speakers EQ is not compatable for this AVR. Is there a list of compatable receivers for these speakers...seems confusing...should I return the speakers or...
You might be faced with the age-old Bose issue of a 4-ohm speaker set. The ohm rating must be compatible. Most receivers drive 8-ohm speakers. If indeed they are incompatible, then it's up to you which component you want to replace (I don't recommend trying to find a converter to use the Bose speakers). The receiver sounds like it is new, so perhaps the speakers... or return the receiver and get one that can drive the Bose.
Dec 24, 2008 | Bose 901 VI Main / Stereo Speaker
Subwoofer blows internal fuse when receiver is turned on
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
Dec 12, 2008 | Bose Acoustimass 16 Speaker
Receiver for Bose AM-16 6.1 speaker
i added the vcs 10 center channel speaker for 180 to "upgrade" to the 7.1 and bought a new pioneer vsx-91txh receiver on ebay for 515.
Feb 14, 2008 | Bose Acoustimass 16 System
"Check Speaker Wire" error on my Yamaha Receiver
found the source of the problem with "Check SP Wires"! to solve it is necessary to check each speaker connected to the device Yamaha on the rear panel (red and black) using the device for determining the number of ohms, which shall not be less than 4 ohms, in large passive speakers experienced in Amfitone AU-027, the result showed that left at 0.45 (7) ohms, and the right-hand column, as such, no.
The successful test ... and good music!
Mar 13, 2007 | Yamaha HTR-5790 Receiver
KLH R5100 Receiver Logo
101 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
