Time to replace Kenmore FL?
A few weeks ago my 9-10 year old Kenmore washing machine started leaving brownish black stains and streaks on some of my clothing. Not every load -- maybe every 2nd or 3rd load. I cleaned the machine by running a hot cycle with bleach, then a hot cycle with vinegar. Things seem better and the stains are lighter but it still happens. It also seems to be noisier than usual during the spin cycle (though that might be my imagination after reading all the posts about bearing failure.
Is there a simple way to tell if the bearings are bad without shelling out the $70+ for a service call? If they're shot, what are some reliable and affordable models you would recommend for replacement.
FYI -- the machine receives relatively light use (averaging 2 loads a week) so I would have expected it to last longer under those circumstances.
Thanks.
  • 15,935 Answers
Grab the drum and try to move it in and out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
My LG Front Load washing machine is leaving black streaks and smudges on my clothing. These streaks and smudges are ruining my clothes!
There can be several things that can cause this problem. The most common are:
1. Fabric softener - did you switch brands lately?
2. Chlorine bleach - if added at the wrong time
3. A mechanical problem with the washer, like a leaky transmission leaking oil.
4. Rust staining, sometimes caused by the water being used in the machine.
Here is a link to a site that discusses this issue more in depth:
http://www.stain-removal-101.com/washing-machine-stains.html
Jul 26, 2015 | LG Washing Machines
I get brown streak type stains on my clothes regularly. They are about 1 to 3 inches long and orange-brown in color. They are very difficult to remove. I have a 5 year old Kenmore Elite top loading...
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore Washing Machines
My front load kenmore leaves faint dark streaks in
look carefully inside the tub, gasket, lid. There may be some debris of some sort stuck somewhere causing this problem.
Then run the machine adding only two cups of vinegar. this will clean it.
Aug 20, 2009 | Washing Machines
Brown stains on white clothes in front loading washer
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Jun 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Feb 20, 2009 | Kenmore Elite 21086
Old washing machine is starting to leave grey streaks on clothing
hmmm..let's see..sounds like you have some residue accumulating from something possibly seeping into the tub. That can be old rubber, a metal sheath, or even an leak of lubricant. Like an old car, there are parts of every mechanical device that need to be attended to.
I'd recommend you find the most seasoned person that works on older machines, to come by and assess what is 'leaking' on your clothing. Grey comes from something metallic or rubber/plastic.
Hope you can solve this one, and keep that old machine happy.
Feb 19, 2008 | Washing Machines
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
