Question about Samsung HL-P5063W 50" Rear Projection HDTV
DLP Image I have installed a new color wheel in a Samsung HLP5063W; and the image is a bit out of focus, and the dark areas of the picture are "washed out" --no detail in them. Unit is three years old and other components have also failed (fan). dark areas don't show image clearly
  • Anonymous Mar 18, 2009
    I have the exact same problem, my color wheel failed (bearings) at 13 months, I did not purchase the extended warranty from Circuit City, I assumed Samsung would stand behind their product. Bad assumption. So I purchased a color wheel from The Parts Store.com and changed the color wheel, that has been two years ago and I have been living with the dark scenes with the green hue since. Sporting events look great, but it has about driven me to purchase a new TV. If indexing is all I need then I'm all for that. I like the TV, but it looks like $&i! right now. Thanks for the info and now I'm off to find a service tech here in middle Georgia who can do this without screwing it up. Great blog by the way!!!
Did you switch from a bearing Color wheel to an air type bearing? If so,you have to remove the jumper on the board.
Posted on Apr 19, 2009
    Novelist:
  • 184 Answers
In some cases,after installing a new color wheel, the speed of the wheel motor must be adjusted to obtain proper speed to ensure a satisfactory image. Unfortunately, you can not and should not attempt to do this adjustment yourself as the service menu contains many adjustments which if accidentily mis-adjusted may cause irrepairable harm to your TV. Ask a local samsung servicer to do an "index delay" adjustment in the service menu.
Posted on Feb 17, 2009
Need help fixing the picture on an older Samsung dlp tv
You need to replace your color wheel. Part# BP96-00674A. This has been a common problem with the samsung dlp's. I hope this helps.
Apr 23, 2016 | Samsung HLR4667W 46" DLP- DIGITAL LIGHT...
Samsung dlp the picture is all shadows with dark green/black colors after replacing with new color wheel..what is wrong? Is it a bad color wheel?
no you need to adjust the color wheel to factory specs by getting into the service software. The color wheel has to be timed to the engine.
Dec 29, 2013 | Samsung Bp96-00674a Dlp Tv Color Wheel...
Colored spots on Samsung HLP5063W
The color wheel or the DLP chip itself will cause this. Parts can be had here: www.shopjimmy.com
Jun 27, 2017 | Samsung HL-P5063W 50" Rear Projection HDTV
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
MY SAMSUNG DLP MN HLP6163W PICUTURE HAS FADED
If you have had this unit for awhile it could just be the lamp. If the image does'nt brighten up you may have an issue with the light path. The color wheel produces the color. If there was an issue with the color wheel you would most likely have a black and white image.
Jan 24, 2010 | Samsung HLP6163W 61" Rear Projection...
Samsung HLP5063W DLP
no you do not need a bulb you will need to have the color wheel replaced.
Aug 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
Mar 31, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
DLP Image
I heard people say they adjust the speed of the color wheel and also the blub will cause the same problem. i don't know where the adjustment is located.
Feb 03, 2008 | Televison & Video
DARK HORIZON AREA AT TOP OF SCREEN
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Jun 07, 2006 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
374 people viewed this question
Henry  Thomas
Henry Thomas
