Question about Epson 4880 Stylus Pro InkJet Printer
Epson 4880 Stylus Pro InkJet Printer maintenance error 0040
nyilasrobert
  • 627 Answers
SOURCE: Maintenance required 0040
Turn off printer
Hold PAPER SOURCE+PAPER FEED+CUT/EJECT buttons at the same time and keep them pressed
Turn on printer
Release buttons
Hidden new menu appears
press DOWN, “CLEAR COUNTERS” option should appear
press RIGHT
press UP, “MAINT TANK” should appear
press RIGHT
press ENTER (CUT/EJECT button)
Turn off printer.
Posted on Jul 17, 2009
SOURCE: EPSON STYLUS 4000 MAINTENANCE REQUIRED
While powering up the printer, hold down the three leftmost
arrow buttons:
[left-arrow] [down-arrow] [up-arrow]
You will get a whole different set of menus.
Use the up/down arrow buttons to select the "Clear Counters" menu, then press the [right-arrow] button.
Use the up/down arrows to get to the maintenance tank entry... where you can clear its counter.
Then turn the power off, wait, then turn it on.
You can use this diagnostic startup to clear most of the counters (and their related maintenance codes).
Posted on Mar 23, 2010
rcw1962
  • 2571 Answers
SOURCE: Maintenance request 0040 is showing
If you ring epson, they will charge $456.15, i found this forum that may be of help http://www.minilabhelp.com/forum/Blah.pl?v-print/m-1119948275/
one answer posted is this
Please follow the following instructions precisely?.
1) POWER OFF
2) Hold down the ?Paper Source? button + ?Cut Eject? button + 1 paper feed button (Down arrow)
3) POWER ON, whilst holding the buttons.
4) ?View Counters? should appear on the display, so press ?Paper feed? button down until ?Clear Counters? is displayed.
5) Press ?Select type? button + Paper Feed button + wait until ?Cleaner? is displayed.
6) Press ?ENTER? button TWICE
7) Switch machine OFF
8) Switch machine ON
Outcome
The error display should then have disappeared, and should read READY
IMPORTANT
This process can ONLY be followed ONCE before an engineer is required.
Hope this is of help
Posted on Oct 27, 2010
  • 158 Answers
SOURCE: we have an EPSON STYLUS
The codes should be in the owners manual. Otherwise go to the web site in the support area. Type in the printer model then look for error codes support.
Posted on Mar 01, 2011
caroldon
  • 17130 Answers
SOURCE: maintenance req 0040 on my
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Posted on Aug 09, 2011
What does "service req. - 00010005" on epson 4880 printer mean?
http://largeformatrepairs.co.uk/errors/epson/sp4880/00010005/
Quoting from the link above:
Service Call Error 00010005 CR Motor Out Of Step During CR Motor operation, there may be a case where the encoder pulse signal within the specified range is not input within a specified period of time or the pulse width is extremely long or short. In such a case, the CR Motor is judged to be out-of-step, so that this message is displayed and the printer stops operating.
This error occurs on the Epson Stylus Pro 4880 large format printer and is not a routine maintenance request.
May 02, 2018 | Epson Office Equipment & Supplies
The error code 0040 appears on my epson 7880. How can I solve it? Help me please!
You probably need a maintenance kit. It consists of new ink waste padsicon1.png, a purge unit, and some other little parts. Contact Epson support
Jul 30, 2015 | Epson Stylus Pro 7880 InkJet Printer
MNT TK NEAR FULL what should I do replace mnt tk or cleaning the tank?
maintenance tank problem Epson 4880
I have my Epson pro 4880 down for four weeks. The Maintenance tank is rejected by printer. I bought brand new waste tank sensor and chips still says: "NO MNT TNK" it also would let do media setting through Epson LFP remote panel at all. I need help of what may be wrong. please???
Nov 16, 2012 | Epson 4880 Stylus Pro InkJet Printer
We have an EPSON STYLUS PRO 9600. We have received the msessage MAINTENANCE REQ 0040. Can you help us, please? Thank you very much.
Mar 01, 2011 | Epson Stylus Pro 9800 InkJet Printer
Epson styllus pro 7800 service call error 0001002d.. help
http://www.largeformatrepairs.co.uk/technical/maintenance-error-code-0001002d.htm
This happens when you let the "maintenance req. 0040" go for to long. The machine turns itself of to prevent damage.
Solution: Call epson and they will give you the reset code. Cannot find these codes online so if you do call please post instructions
Please rate the answer........
May 07, 2010 | Epson Stylus Pro 7800 InkJet Printer
Maintenance request code:
The pump counter is near end of life, replace the cleaner kit ASAP.
This is what 0040 means.
May 03, 2010 | Epson Stylus Pro 9800 InkJet Printer
Epson 4880 Stylus Pro InkJet Printer Logo
1,076 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
