Hotkeys not working on zoostorm laptop
The WIFI fn F11 is not working and an error message saying hotkeys have stopped working, what do i do?
sandrew
  • 2961 Answers
SOURCE: Hotkey Combination Fn - F10 F11 F12 doesn't work
I don't think it's a Windows problem, it will be notebook driver fault. The drivers for your keyboard hotkeys may need to be installed again or enabled. The driver will be on the cdrom that came with the laptop or on a seperate partition of your hard drive, normally in the restore folder, but just install drivers not a full restore.
Posted on Dec 31, 2006
shuttle561
  • 32 Answers
SOURCE: Fn+F8 hotkey dose not work but the remain FX go fine
Another Alternative is to check your BIOS to see whether or not your Wireless is turned on, if it is not pressent in your BIOS then update your BIOS Driver on the Internet to ver 1.4, Double check your version Compatabillity. Next if the adapter driver is installed, follow the following intructions: start -> settings -> control panel -> system -> hardware -> device manager -> now look for the wireless adapter, see if it is operational or marked with an error -> if it is marked check that it is configured for automatic, and also the resources. Set the configuration manually if so. restart the system.
1) Resource conflict = change resource settings
2) No adapter = check if the adapter is enabled (Y) then see if there is any conflicts (y) correct the settings e.g. resources and see if windows shows that the device is enabled (N) try to enable this device. If (N) then goto BIOS settings to correct it.
Hope this helps
Posted on May 24, 2009
iklln6
  • 35 Answers
SOURCE: what is the hotkey for Print screen
On PC:
1. Press the "Print Screen" button. This will copy a screenshot (like copying text). 2. Open MS Paint and press CTRL+V to Paste the screenshot. 3. File-->Save As... and save the screenshot to wherever you want, and be sure to change the file type from the drop down menu (or just type yourfilename.jpg if it is an older version.) The default is (or at least used to be, before I switched to Mac) .bmp which will create a relatively large file; too large to easily transfer through the internet.
On Mac OS X:
1. Press Command+Shift+3 or Apple+Shift+3 depending on the age of your keyboard. 2. Find your screenshot on the desktop. It will be titled 'Picture 1.' If I am not mistaken, it will have the extension .png.
If you would like to change the extension to .jpg, go to www.apple.com and search their downloads for a program called Deeper. It is a free app that allows you to modify many hidden settings within your mac. One of which changes the default extension to screenshots.
Posted on Jul 09, 2009
  • 202 Answers
SOURCE: hi i have an advent 4211-b netbook. the keyboard
use virtual key board for fn key do google for it.
Posted on Feb 04, 2010
SOURCE: amilo pro v3515: the hotkeys fn+up for brightness
you need to download a driver called "hotkey utility" and the buttons will work again
go to :http://uk.ts.fujitsu.com/support/downloads.html
search for v3515
you will find a list of drivers , scroll down a alittle and you will find hotkey utility , download it , install it ...... try the buttons :) MAGIC
Posted on Nov 28, 2011
I have MSI U100 Notebook and I recently installed Windows 7. After installation, the Wifi is always on. The hotkey Fn+F11 is working the green led too but the Wifi card isn't turning off the Wifi.
Have you updated the drivers for your wifi-card?
There is two places you can go
One is the Msi website the other is the wi-fi card manufacturers website.
It could also possibly be the driver for the FN keys thats need to be either re-installed or updated
Jan 27, 2017 | MSI Computers & Internet
My Acer laptop says it is not set up for wifi and I can find no wifi switch
Sometimes the WiFi switch is what is called a hotkey or soft switch. As long as the correct drivers are installed. Usually you will have a key that has fn on it. That is the function key. 05d5d4cf-e6cf-41c6-890c-9a5721560f4b.jpg
You will also see a key that will have either an antenna or what looks like parenthesis:
395e72c1-8a47-4ced-8774-56d5ccf1cf3b.jpg or ed68b642-ce74-46bc-825f-3843ef2cf72c.png
Hold the function key and press the wireless key and it should work.
Jan 15, 2014 | Acer Aspire E1-571-6650 Laptop
Backlight & volume fn hotkeys g73jh not working
restart and HOLD the key f2 or esc for enter the BIOS setup, and adjust the hotkey, Enable.
God bless you
Jul 24, 2013 | ASUS G73JHA1 Notebook
Restore FN + F8 key to reactivate Wi-Fi on Toshiba Satellite L500
My laptop didnt enable the wifi with the fn+f8 key.
I even reset the cmos and nothing.
Then I went to toshiba drivers website and after installing the "thku" "toshiba hotkey utility" the fn+f8 start working and enable/disable the wifi. It now shows a popup windows when I press the fn+f8 key.
Before the wifi led was always off. Windows detected the wifi device but nothing on the wifi available list.
Now the led is always on, starts orange when I turn on the pc and blue when connected.
Oct 05, 2012 | Toshiba Satellite L500 Series Notebook
How do i disable the f keys
Hi There,
After a few hours of research, it looks like the function or F keys under windows are pre-programmed and there's not a whole lot you can do to change it. There are, however, a few options:
Keymapping software: Usually ships with (and free to download) logitech or other gaming keyboards. The software allows you to reprogram any key on your keyboard to do what you want it to.
Hold down Fn+F11, while still holding F11 let go of Fn. Some laptop users have reported that this turns off Fn keys. Also, Holding down Fn+Scroll lock or Fn+Num lock in the same fashion has had varied results.
Jun 06, 2012 | Compaq Presario Notebook Notebook
How do i turn on my wireless on msi u130?
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
May 14, 2011 | MSI Wind U100-030US Laptop
I use TOSHIBA Satellite M200 notebook and have problems : 1. FN key did not work I can use only FN+F10 and FN+F11, other FN+key didn't work. 2. All hotkey buttons (locate next...
Hi
There is software utility missing from your laptop
you can download it from TOSHIBA Satellite M200 website under ( keyboard utility )
Please tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite P105-S921 Notebook
Hi,my laptop is Asus X42J,the problem is the Fn key,don't know why Fn + F11 and Fn + F12 cant set the sound volume,before still can...not only this 2 key,Fn+V and Fn +C also fuctionless ...but Fn + F1 and...
Hello there. Follow my steps:
  1. Go to support.asus.com
  2. Select "Download" (if you don't see a "Download" button due to being in another language, select the last item from the main menu and select "English)
  3. Find your laptop model using the wizard
  4. Select your operating system (to determine whether if it's a 32bit/64bit, go to your start menu > right click on "Computer" for Windows Vista/7 or "My computer" for Windows XP and look for a text which says "XX bit operating system)
  5. Go to the "ATK" tree
  6. Download the "ATK Hotkey Utility" thingy and install it.
Mar 16, 2011 | ASUS Computers & Internet
I own a Lenovo 3000 m2000 and the internet wifi has stopped working. I believe I may have turned it off via the Fn (funtion) key, but I don't know what keyis assigned to the wifi. Can you help.
most pc's differ,some have just one button that switches wi-fi on/off.mine uses a hotkey sequence Fn-F2.consult manufacturers site/manual for correct key/sequence--good luck!
Davey Snake!
Oct 28, 2010 | Lenovo Computers & Internet
I can not work out how to turn the wireless conection on.advent 7070.what keys do i use
To enable the Wireless LAN Fn + F2
usually the wifi function key has the universal antenna symbol with radio waves emanating from it.
The manual says the other hotkeys are:
Fn + F2 - Wireless LAN
Fn + F3 - Standby
Fn + F4 - External display
Fn + F7 - Reduce brightness
Fn + F8 - Increase brightness
Fn + F9 - Play / pause media
Fn + F10 - Stop media
Fn + F11 - Media previous chapter
Fn + F12 - Media Next Chapter
Fn + scroll - Scroll Lock
Jan 14, 2010 | Advent Netbook
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
