Question about Toshiba e-Studio 232 Black and White Copier
Unable to setup Faxing on E-Studio 232
I have the estudio 232 for my office but i cannot seem to setup the fax portion of the device. I am able to print % scan to email on the unit but when i try to fax with a number i get message "Group consists of only Tel number"
Any suggestions?
  • Toshiba Master
  • 643 Answers
Did your estudio 232 came along with fax board, where there is a RJ11 port onboard for phone line?
Posted on Mar 10, 2009
  • didi2005 Sep 17, 2009
    Did u install the fax kit?
Error code ca20
toshiba estudio 232 errr ca20 wt problems?
May 25, 2013 | Toshiba e-Studio 232 Black and White...
Linux print to eStudio 232 printer
Did u install the driver?
Driver can be downloaded at below link:
http://www.eid.toshiba.com/support/controllers/ebridge282-283%20series.shtml
Aug 05, 2009 | Toshiba e-Studio 232 Black and White...
Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
May 04, 2009 | Toshiba e-Studio 232 Black and White...
Fax received is at least twice as large as fax sent
I made the tech come in since they say we can't do this ourselves
Jan 26, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
I can send a fax, make copies, but cannot receive a fax on my HPL7590. Help
hi tbacsa02,
this was a solution i posted earlier with someone that has the same problem like yours.
follow this few steps;
first can you try this;
You can test your fax setup to check the status of the device and to make sure it is set up properly for faxing. Perform this test after you have completed setting up the device for faxing. The test does the following:
• Tests the fax hardware
• Verifies the correct type of phone cord is connected to the device
• Checks that the phone cord is plugged into the correct port
• Checks for a dial tone
• Checks for an active phone line
• Tests the status of your phone line connection
The device prints a report with the results of the test. If the test fails, review the report for information on how to fix the problem and rerun the test.
To test fax setup
1. Set up the device for faxing according to your particular home or office setup instructions.
2. Make sure the ink cartridges are installed, and that full-size paper is loaded in the main tray before starting the test.
3. From the device control panel, press Setup.
4. Press right arrow to select Tools, and then press OK.
5. Press right arrow to select Run Fax Test, and then press OK.
The device displays the status of the test on the display and prints a report.
6. Review the report.
• If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause problems faxing.
let me know.
Jan 21, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Faxing to a residence
It may be that your CEO's fax machine is not setup to receive correctly. Have someone check the fax receive settings. Have them set it ot fax only and automatic receive.
Please remember to rate all users who assist you for free :)
Sep 26, 2008 | Lexmark X6170 All-In-One InkJet Printer
Toshiba e-Studio 232 Black and White Copier Logo
345 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
