Question about Rinnai R98LSiN
What are the Rinnai RU98i NG dip switch settings
2 Suggested Answers
SOURCE: Dip switch settings for Rinnai V1200 & V1500
curios to find out if you had any help on this subjuct at all?
Posted on Aug 01, 2010
Can Richmond tankless heater which is now LP be converted to natural gas?
If it can, then it is done with dip switch settings.
Read your product manual.
Switching types of gas, and messing with dip switches is dangerous.
LP gas burns much hotter than NG, and LP pressures are much higher than NG
Call Rheem with serial number and they might supply the information to you, but will likely tell you to call service technician... leaving you in exact same spot you are in now.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
Sep 29, 2014 | Rheem Richmond Encore Tankless LP Gas...
Can you convert a natural gas rc80i n waterheater to propane
Contact manufacturer.
Generally the answer is probably no, especially if you have a family, children, dog and neighbors.
Propane burns Hotter and has more pressure than natural gas.
Burner must be more robust cast iron.
Orifices must be changed to accommodate different gas.
Different gas control valve needed.
In some cases there are dip switch changes for type of gas and altitude above sea level ... the higher the elevation, the hotter gas burns.
Here is expected result from changing NG to LP.
But your good luck might lead to less volatile result
http://waterheatertimer.org/images/Exploded-house3.jpg
Apr 21, 2013 | Rinnai RC80i Tankless Water Heater 8.0 GPM...
What does it take to convert a Rinnai R75LS water heater from propane to natural gas?
Contact Rinnai.
Gas control valve is different, burner is different, burner and gas valve must match, threads are regular instead of reverse, dip switches probably have to be changed since combustion of NG is not as hot. Maybe different sensors. Pressures are lower with NG.
Mar 28, 2013 | Rinnai Water Heaters
Water does not stay hot
Had this trouble with a condensing boiler,water pressure was too low, also if thereis an adjustable stat try turning this up ?
Jan 26, 2013 | Rinnai RU98i-N Interior Natural Gas...
Rinnai 2532 error code 10
Error Code 10 Problem: Reduced or no air supply to the water heater or there is an obstruction in extracting the flue gases out.
Solution: Make sure that the recommended Rinnai venting is used, there is no obstruction in the venting system, no reduction in diameter and lengths are per instructions. Also make sure that nothing blocks the venting system or fan, and that dip switch and condensation collar are set properly.
Good luck,
Marty
Jan 20, 2013 | Rinnai Water Heaters
What does code 79 mean for the rinnai RU98i? It is beeiping and flashing 79
There is water leakage internally. Possible tank or water inlet or water entering from the combo air inlet/exhaust pipe.
Jan 09, 2013 | Rinnai Water Heaters
Change dip switch setting and were are the located ?
Dip switches are located on the circuit board.
These switches are for changing temperature and altitude etc, and depending on brand and model, the switches settings are different.
Oct 16, 2012 | Rinnai R98LSiN
Rheem RTG53DVP code 82
Before calling service technician, open following link for resources including error codes, Rheem chat and possible manual:
Error codes are considered start-point for troubleshooting, and give service technician direction for isolating problem.
Error 82 appears as 'gas type data failure' > 'Program PC board for proper gas type.'
Gas type is choice between LP gas and NG natural gas.
Gas type programming is controlled with dip switch setting.
I do not have service manual for product, and would not suggest changing dip switches without specific information beforehand.
Aug 16, 2011 | Rheem RTG53DVP Direct Vent Liquid Propane...
Aug 24, 2009 | Rinnai Water Heaters
Temperature adjustment for Rinnai infinity 20 hot water heater (with out using remote controllers). Dip SW1 is used for temp control via configuration of 6 dip switches.
You'll find all the information you need at http://www.rinnaiuk.com/download.htm
PDF's include schematics for all dip switches
Please note: you'll need to get the pdf that corresponds with the correct model you have.
Feb 28, 2009 | Water Heaters
Rinnai R98LSiN Logo
346 people viewed this question
Top Rinnai Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
