Question about Kenmore Dryers
Kenmore dryer 8820293
Ordor coming from dyer
5 Suggested Answers
SOURCE: kenmore elite home dyer won't heat up
Here's the tech manual, but you're going to need an ohm meter for testing. Here's the Tech manual https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203979621.pdf
Good luck.
Posted on May 02, 2009
localwonder
  • 6784 Answers
SOURCE: dryer timer not working on a kenmore dryer model 80 serious
HI, if this device isn't working, you will need to replace it. it cannot be repaired. it is designed to fail and when it fails, you will have to replace the entire timer control module.
This device control all aspects of the cycle you initiate.
Posted on May 23, 2009
  • 120 Answers
SOURCE: Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Posted on Jun 04, 2009
  • 60 Answers
SOURCE: kenmore dyer part # EL1345062 Kenmore 64952 /
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
Posted on Nov 03, 2011
Reset after power outage
Assuming this is a 220 volt dryer, are both sides of the breaker on? It should not blow only one side of the 220, but worth checking.
Jan 26, 2014 | Kenmore Dryers
Can I use a 3 prong dryer cord on the Kenmore Elite Oasis dryer?
Most dyers are 220V. If the chord is connected to three terminals as most dyers have, then it would work just fine. Just be sure you connect the ground wire correctly.
Apr 08, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
HOW DO U PUT A BELT ON A KENMORE DYER
You,ve got to flip it over and loosen the tension pully. The old belt should come off, then replace the belt and tighten the belt with the pully by moving it over.
Nov 27, 2009 | Kenmore 63942 Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Gas dyer not heating up
Most of the gas dryers have everything accessible by simply releasing the spring clips atop the toe panel and getting it out the way.
Here are some repair pix with manual
Sep 05, 2009 | Kenmore 63942 Dryer
Jun 04, 2009 | Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmore dyer
I have a kenmore gas dyer, it will start to dry then go out and just run. you can shunt it dwn resit the timer the time it needs start it and it will lite for a cycle then go out, short burn, then out. is it a senor???? JW
Jun 09, 2008 | Kenmore 62802 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
