My technics sa eh780 goes silent when volume turned up, the graphic equaliser still show sound coming through?
2 Suggested Answers
SOURCE: Technics SA-AX730 Receiver PLAYS FINE AT A VERY LOW VOLUME.
Have you checked to see if your fan is still working.....I am having the same issue but I think it's my fan b/c it was doing this when I first got it and for the 1st couple of years.
Posted on Jul 31, 2009
The volume gets noisy, cracking sounds and fades out
Your volume control is dirty. Apply some deoxit or wd40 directly onto the module.
Mar 22, 2014 | Panasonic Technics SA-G76 AV Control...
Connect a denon amplifier pm-510ae to a technics equaliser sh-8058
Hi Just to let you know what ever you put between the amp and speaker you will degrade the sound quality. Even with the best machines you will muddy the sound. If you read HiFI magizine they will tell you this is true.
But if you don't care about the quality of sound than go ahead hook an equalizer on it. Hope that helps you.
Mar 27, 2012 | Denon Audio Players & Recorders
Following a split from my boyfriend I really need some help in how to connect up my hifi system. It's all technics Tuner Receiver ST 610L Equaliser SH GE70 Amp SU V470 CD Changer SL...
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Jun 14, 2011 | Technics SH-GE70 Home Equalizer
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Technics sa-dx940 tv volume control
Check the sound setting on your TV, is it Fixed level out, if so you have to turn volume up on TV to go through the receiver.
Mar 19, 2009 | Technics SA-DX940
Technics SA-DX950 intermitently sounds blown out
There are poor solder connections at the output amp pacs and the voltage regulators. Once these are resoldered the problem should go away. If you can solder, resolder any connections that appear grainy or have rings. If you can not, this should be effectively a labor only repair for any shop that works on audio gear.
Dan
Feb 18, 2009 | Technics SA-DX950 Receiver
Technics sa dv280 hard reset
DESOLDER THE REGULATOR AND CHECK IT OUT AGAIN IF IT'S OK THEN REPLACE THAT BIG GREY AMP PART STICK TO THE RADIAROR ON THE BACK
Nov 16, 2008 | Technics SC-EH780 CD Shelf System
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Technics sa-g78 no sound from front speakers
This happens on mine also. My theory is a relay. If you turn the volume up (Waaay up) momentarily, you "burn through" the oxidation on the relay and the sound comes back - for awhile. Some day, I'll get in there and replace it with something more robust.
Aug 06, 2007 | Technics SA-AX540 Receiver
29 people viewed this question
 Grubhead
Grubhead
