Question about Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting
Homelite Bacpacker blower won't crank.
Model no.UT 08017 K. Oil accummulates around the carb area. I cleaned this area an d installed new plug. Still will not crank. Suggestions/
  • 47 Answers
Does it try to fire or nothing what i suggest is check the spark arrestor in the muffler it looks like a little screen when you remove it you should be able to see through it if not it needs to be cleaned and the only way that i found that works is to burn it out with a propane torch if thats not the case then let me know
Posted on Feb 05, 2009
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
Homelite ut-08068-r leaf blower leaking fuel
If we are talking about a hand held leaf blower. The fuel leaking from the carb is likely caused by a stiff metering diaghram holding the needle open. Rebuild your carb ( I suggest also replacing the fuel lines and primer bulb while you are at it) and double check the lever adjustment.
Oct 23, 2012 | Homelite Garden
I have a homelite hand blower model no. UT 08544, it runs great and for ever when I hold it pionting up. When I point it down to blow the sidewalk it dies. Restarts easy when pointing up again. I took the...
wrong hoses connected to the carby
one hose is for suction and has a filter on the end , the other is return
pointing down the hose is out of the fuel
pointing up it is back in the fuel
Jan 24, 2018 | Homelite 'Yard Broom' Leaf Blower
Trimmers: Homelite Easy Reach-25cc-Model # UT20044B& Homelite Mighty Lite- 26cc- Model # UT21546 Both trimmers will start but when throttling up they cut out. They will also cut out when the choke is...
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Sep 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
May 15, 2010 | Homelite Consumer Products MightyLite...
I am looking for carb kit for my homelite leaf
Does your model #ut-08010, Have a letter after it. Homelite lists 5 or 6 models of that unit. Plus the kit they show is a complete carburetor with gasket. You will have to figure out which carburetor they put on your blower. Either a Walbro or Zama carburetor and it model to figure out which kit it will need. The homelite kit lists for about $67.00 USD.
You can go to www.precisionope.com and look it up under OEM parts.
Hope it helps.
Good Day.
Oct 20, 2009 | Homelite Garden
Gas/oil ratio for a Homlite UT 08026H blower?
I USE SOME STUFF CALLED OPTI THAT WAY YOU ONE CAN FOR ALL YOUR 2 CYL STUFF ITS GOOD STUFF
Sep 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Hard to crank, will not idle.
You will need the brand and model number of the carb. If you can not find one in your local area contact southern supply company at 205-833-2525 or email them at
southern.supply@mindspring.com and I feel sure Jason or
someone there can help you.
Sep 09, 2009 | Garden
Homelite 2 cycle backpack leafblower won't run.
yea check the gas lines and throttle cables for strech, probably need replacing or tightening.
Jan 03, 2009 | Homelite Consumer Products Backpack...
Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting Logo
244 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
