Question about IBM (25P3294) Motherboard
Board does not recognize cd rom nor hd
Pentium 2 cpu/mb, 1.44 floppy recognized, but nothing else, no hd, nor cdrom.
all cables connected, do I need drivers?
  • pastorgillet Jan 19, 2009
    thank you, any ideas as to where drivers are?
  • fetus_pako Feb 05, 2009
    cant find hard drive bad this is the language of the bios is german.
  • 52 Answers
Yes u do
Posted on Jan 19, 2009
My desktop is not finding the cd rom hardware plz help it tried 2 cd romz but non was recognized plz help i use xp service 3 dell optiplex gx240
If you have the power cable connected to the cdrom and the data cable (ide or sata) then as long as the cd rom drive is working it should be detected automatically. If the back of the cdrom has a jumper make sure it is set to cable select. Finally go into bios (hit F2 when you see the Dell Logo) and see if there is a setting to enable the cdrom drive. It may have been disabled for some reason. If these fail then its possible the cd drive is bad.
Oct 15, 2011 | Dell OptiPlex GX240 PC Desktop
Computer not reading the hard drives or cd rom drives
You first need to make sure that inside, the hard drives and cd roms' connectors are all firmly seated.
When you first turn on your PC, you can normally enter the BIOS mode, (before windows) by pressing the del key or f2 key. Once there you can make sure that the drives are being recognized. If they are, you would need to go to the boot section and enable hard drives and cdroms.
If they are not recognized,
Old IDE hard-drives (the ones with lots of pins on the back) (newer ones are called SATA and have plastic connectors) .. Old ide hard drives had a special jumper (little plastic rectangle on two pins) to indicate if it would run as a master or a slave drive. So your two drives should be connected accordingly.
If all the above sounds too complicated you would need to contact a friend savvy in the area.
Aug 11, 2009 | Dell OptiPlex GX260 PC Desktop
Pc does not recognize the cd rom. is everything connected right?
please open the system, connect one of the extra power connector from the power pack inside, and there is another that connects it to the board am sure thats what the problem is if not, get a new one. thanks dont forget to rate me if it works thanks
Jul 16, 2009 | Computers & Internet
Can't boot with Cd-Rom unable to install windows XP
Well, maybe I can try, thus in your bios setting you can boot using usb cdrom? Or maybe its time to change your cdrom drive already. If you can borrow a good spare cdrom. Take this in for the meantime in exchange for your installed cdrom. Maybe your cdrom drive is faulty. Then if this is ok, it is now easy for you to get on.
Second option, you can take out your harddrive prime it, then have a partition (say d:\) with a copy of full copy of xp installer, and other important installer just have it foldered. Then I assume you can boot using a floppy drive with win98 rescue disk. After booting goto harddrive partition with xp installer. then click setup and set it up in c:\ . Then your go other software, installed it manually.
I do this coz it much faster to installed using harddrive and also it is only in xp.
Hope this helps. comments if I miss something.
May 05, 2009 | Microsoft Windows XP Home Edition
Hard Drive not found after installing software.
  1. Boot to the bios with the HDD connected
  2. Turn on all the lock lights on keyboard (SCROLL< CAPS<NUM)
  3. Press ALT+E (Wait for Beep)
  4. Press ALT+F (Wait for Beep)
  5. Press ALT+B to reboot
  6. IDE redetect should initialize on boot.
  7. HDDs should now be seen
Sep 29, 2008 | Computers & Internet
Does not boot to floppy/cdrom/ or hdd
check ur hdd and cd rom cables , r they okay or may be even loosen from the board.feel frree for further assistance.bye
Jun 07, 2008 | Matsonic MS9127C Motherboard
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Need specs on ax6b mb
CPU: Intel Pentium III / Intel Pentium II / Intel Celeron slot1
ASIC: Intel 440BX AGP set
Architecture: 3 xISA slots + 4 x PCI slots + 1 x AGP slos
Max. Memory: 1 GB SDRAM for DIMMx 4
DIMM Type: 8/16/32/64/128/256 MB
BIOS: AWARD plug-n-play flash ROM BIOS
On Board I/O:
2 serial ports (UART 16C550 supported)
1 parallel port (SPP/EPP/ECP supported).
2 floppy drive supported (1.2/1.44./2.88 MB)
2-channel IDE (PIO Mode 4 and ultra DMA/33 bus master supported)
2 USB ports supported (universal serial bus)
1 PS/2 Mouse Port
1 PS/2 Keyboard Port
On Board SCSI: Adaptec AHA-7880P ultra wide SCSI controller
SCSI Port: 68-pin wide SCSI and 50-pin FAST SCSI connector yes
Battery: 3V lithium battery
Green Function: Yes
Connector: IrDA, Wake On LAN, SB-LINK,Wake On Modem
Board Size: 244 mm x 305 mm, ATX form factor
Apr 13, 2008 | Computers & Internet
Motherboard fails to see Hard Drive...please help
Sounds like you lost an ide channel, swap the ide cables around, primary to secondary and secondary to primary. and see if it recognizes the hard drives and not the cdrom.
I lost an IDE channel and had to install a sata hard drive or run the hard drive and cdrom on the same ribbon. If you run HD and CDROM on same ribbon set both to CS (cable select)
Mar 23, 2008 | Dell Dimension 4600 PC Desktop
Machine won't recognize CD-ROM after harddrive format
You have to change it in the bios, press F2 or DEL on startup depending on your bios type. The bios screen then will have second line of advanced bios settings, in here you need to select the cdrom as the first boot device, by using the up down arrows or pageup/down or '+or-' keys. Press ESC when cdrom selected and save settings when propmted. The system will re boot so ensure the cd is in the drive and press enter when prompted to start with cdrom.
Jan 29, 2007 | IBM NetVista A40 PC Desktop
IBM (25P3294) Motherboard Logo
187 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
