Question about Toshiba Portege M200 Tablet PC
I'm trying to get into the bios of a toshiba protege m200. i don't know the key strokes to enter the bios
  • 15,935 Answers
Click HERE for an instructive website on the M200.
hold the ESC button down during boot to enter bios.
Posted on Jan 19, 2009
    New Friend:
    Problem Solver:
  • 12 Answers
If its a laptop its F2 and desktops are the DELETE tab
Posted on Dec 13, 2012
I want to know how to reinstall toshiba portege m200
This is in case you cannot boot into windows but you can get into bios:
Open your disk drive. Insert windows operating system disk into your disk drive. Restart your computer.
If you can get to the stage where you can see see bios entry key then keep pressing whatever key it is that you press to get into bios at start up.
Select the option that let's you choose the drive to boot from, mine is in advanced bios options. then go to either something like bios features or change boot drive.select whatever drive represents your CD-ROM drive and select it to be the first boot drive.
then save exit bios, I do this by pressing escape then Y to save and boot from the rom drive.
This will let you restart your installation of windows and
re-format the drive...
If you can boot into windows:
Then either re-format the drive and delete the partition when you do or...
Run a recovery of the system by installing your disk and letting it get to the stage wher it asks what action/task you want to perform and press r when prompted then follow the prompts to repair the files. This might not work though,
you could even try running a disk check as maybe a lucky chance of repair if you can get into windows.
If your PC keeps trying to boot from the CD drive after repair then re-enter bios at start up and change your hard drive back to first boot device to boot into windows.
It's better if you re-format though as repairing windows can be a little tricky.
Aug 01, 2011 | Toshiba Portege M200 Tablet PC
Clear cmos toshiba m200
In case nothing worked to reset BIOS password (taking battery out, reseting jumper J1) you can use thrid party software from Hiren's Boot CD to reset the password. You've got Kill CMOS on there, for example which wipes out CMOS. Here's the download link to the entire CD: http://www.hirensbootcd.org/download/Hirens.BootCD.12.0.zip
Aug 22, 2010 | Toshiba Portege M200 Tablet PC
How can i enter the bios environment on toshiba portege 3500 tablet pc
hold the "esc" key presed during boot, and then pres the "f1" key and you enter to the bios
May 20, 2010 | Toshiba Portege 3500 Tablet PC
Password problems on a Toshiba Protege m200 laptop
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password.
  1. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
  2. On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
  3. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
  4. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
Good luck and more power
nicole
Oct 03, 2009 | Toshiba Satellite R15 Tablet PC
Installing windows xp on toshiba protege 500
When you power up press F2 or "del" to enter in bios .
then set first boot option to as your dvd drive so then put winxp disk then it boot with it.
Jun 21, 2009 | Toshiba Portege M400-S5032X Tablet PC
Disk drive is not working on my laptop
I HAVE A TOSHIBA M200 AND THE CD-ROM IS NOT WORKING . IT DISPLAYS A MESSAGE THAT INSERT A DISK ...... PLEASE HELP ME FOR THIS
May 31, 2009 | Toshiba PA3317U-1ETC - Satellite R10, R15,...
Window shut down
Sounds like a hardware issues. It may be having problems switching from the main power connection to battery.
Apr 22, 2009 | Toshiba Portege M200 Tablet PC
Don't know how to get rid of hard drive password on toshiba lapto
A hard drive password can only be removed by the person who knows the password because then it can be cleared thru the BIOS.
Otherwise the only other way around it is the buy a new hard drive so it doesn't have a password and you can then reinstall the operating system on the hard drive and then put the drivers on it and any other programs that you want on it.
Apr 07, 2009 | Toshiba Portege M200 Tablet PC
How enter to bois
Fadeel, You enter the BIOS on the M400 by pressing the ESC key during the POST operation. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 23, 2007 | Toshiba Portege M400 PPM40U01000E Tablet...
Toshiba Portege M200 Tablet PC Logo
373 people viewed this question
Top Toshiba Tablets & eReaders Experts
micky dee
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
