Question about Refrigerators
GE Refrigerator Main Electronic Board 200D5837G004
catriver
  • 878 Answers
SOURCE: GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Posted on Dec 20, 2007
  • 74 Answers
SOURCE: side by side GE refrigerator psf26pgta
The fan should be a standard 12v DC computer style fan , test that you are getting voltage to the fan connector . You should also be able to get the fan to run by connecting it to a suitable supply . Once you have eliminated the possibility of fan failure then it gets more involved.
Posted on Aug 28, 2008
SOURCE: GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
Posted on Jan 18, 2010
  • 17 Answers
SOURCE: Gene i need thi installation
please send me your e-mail address so that i may send you the installation instructions.
Posted on Oct 21, 2010
oldTech2332
  • 2341 Answers
SOURCE: i NEED TO KNOW THE PART NUMBER FOR THE MAIN
that part # is WR55X10764
Posted on Aug 17, 2011
Have a GE refrigerator side by side came home electronic display was out, food compartment was warm, ice melted in freezer, food thawing but lights were on . What's happening no motor sounds run
Without your model number I can't give you a part number but I can tell you the part. GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to www.repairclinic.com to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair.
May 01, 2012 | GE Refrigerators
Ge side by side refreig where is the defrost timer 2002
If it has a defrost timer its in the control panel by the thermostat that ya set the temp. at ,but i suspect (no model number listed) is that it uses a electronic defrost control which is part of the main control board on the back of the unit
Oct 08, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Hello, I have a few problems with a GE side by side refrigerator. It's a model GSS25JERF CC. First problem was getting no water, then I was sometimes not getting any ice from the door even though the tray...
Trouble described as
EVERYTHING "appears" normal ... "Nothing works"
I have experienced a similar circumstance...
(much older machine)
But I'll stop here & go look for your DEFROST Timer (No)
Or CONTROL BOARD... (Yes, yours = WR55X10942)
Defrost timers can mimic this if the
mountings are loose and the ...
motor runs on "ground" rather than "neutral" (v-rare)...
but circuit boards do fail & cause these issues
easy to change (right lower side on back (@ freezer))...
Purchasing a SPARE
now could save you another
significant food loss & inconvenience in the future
Easyapplianceparts $141.24
Main Electronic Control Board
Appliancepartspros $142.99
GE WR55X10942 Main Control Board AppliancePartsPros com
See video guides
http://www.appliancepartspros.com/ge-main-control-board-wr55x10942-ap4436216.html#videol
Partsselect
http://partsselect.com/
Owners Manual
GE ESH22XGRECC Owner Manual And Installation Instructions Page 72
Mar 24, 2017 | GE GSS25JF Side by Side Refrigerator
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
Dec 10, 2009 | Hotpoint HSS25GFP Side by Side...
Location of GE refrigerator circuit board
The main board is located behind the unit at the lower right hand corner behind a panel that's about 8" X 12".
Oct 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Side by side GE refrigerator psf26pgta
Aug 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
