Question about Kitchen Ranges
Mabe gas stove safety valve failure - Kitchen Ranges
  • 245 Answers
SOURCE: Gas Safety
this is actually how every gas stove is set up and yes it would be a safety issue but there is really no way to change how they work i do wish the people building them would do it with at least a timer or something but that would make the product much more expensive. same type of technology is also used on propane bbq grills btw. it is just something you get used to after a while i have had gas for the last ten years and dont even notice it now
Posted on May 15, 2009
  • 1891 Answers
SOURCE: oven will not light, initiation
looked up your model this is a 2 burner oven top one for broil and bottom for bake . try using the broil and see if it gets hot you can see the igniter in the top of oven and in the bottom of the oven under the plate is the bake ignitor .. i belive that the bake ignitor is not working and will require a replace pt # wb13k0004 .. you have to lift out the bottom plate to get to in find two screws in the back on each side.. , hope this helped mm get back with me for more help if needed . mm feed back pls ..
Posted on Nov 01, 2010
bblizard
SOURCE: Mabe Stove Parts
replacement glass top for mabe gas stove top
Posted on Feb 16, 2011
oldTech2332
  • 2341 Answers
SOURCE: sears kenmore gas oven - bought a new oven safety
The reason the igniter would come on yet not let the gas flow is because the IGNITER IS WEAK and not drawing the proper power to open the gas valve. Replace the igniter nad the oven will work without having to tap on the valve
GENE
Posted on Oct 16, 2011
SOURCE: MABE Stove Manual in English Model : EM6120B2
hello i recently bought a mabe 6 burner gas stove but i need to know the manual is not in english and do i have to plug in before i can turn the gas on? its electronic ignition by the way
thanks
customer
Posted on Oct 22, 2011
I have a mile gas cooktop and the gas does not light .There is no gas coming out of the jet .Is it a electrical problem
First check your gas valve usually located behind the stove and ensure it is on. There may be an exterior valve. Second check the connection to the stove. If these steps fail you may have a faulty unit or need to replace the microprocessing unit that controls the safety features of your range.
Aug 26, 2016 | Cooktops
Oven lights but doesnt stay lit. Does anyone know what the problem could be and how to remedy it?
Safety valve failure. (TURN OFF GAS, then do as follows): Check voltage when the stove is "on" at the safety valve. If it reads 24 volts, then the safety valve is bad. If it reads _less_ than 24 volts, then the ignitor is bad (EVEN IF it is glowing red). The problem is that the ignitors can glow red, but still "eat" so much voltage that the safety valve fails to open (or stay open). It is a "resistance" problem inside the ignitor, even through it appears to be good. // Simply stated: 24 volts at the safety valve means bad safety valve. Less than 24 volts at the safety valve means bad ignitor. (I am certain of this information).
Oct 16, 2015 | Kenmore Kitchen Ranges
Is there anyway to by-pass the gas safety valve on my Magic Chef model # 9112WPW oven. The gas safety valve is no longer in anywhere and it is a very good stove and in very good condition? Can I hire a...
No do not bypass the gas safety valve this is very dangerous. it is there to prevent a gas buildup and an explosion. No professional will touch it
Oct 15, 2012 | Magic Chef Ovens
Atlanta Stove AIT3 model wall stove. will not light unless pilot light is held down...
Most pilot flames for gas burners are controlled by a safety valve. This model has a pilot safety valve. The safety valves function is simple, if the flame goes out for whatever reason the vale shuts the gas flow to the pilot light. The safety valve is controlled by a device that sits right next to the pilot (small cylindrec tube ( thermopile) that senses the pilot flame either by heat or dc current. To ignite the pilot light you have to manually hold down pilot light button until the the thermopile is hot enough (usually 5 to 20 secs), after that time, the thermopile will allow the safety valve to open. Check to see that the pilot's flame is making contact with the thermopile. If it is not, the pilot flame will require cleaning and or adjustment. If it is making contact, the you might need to replace the safety valve and the thermopile.
Feb 17, 2018 | Kitchen Ranges
thanks
customer
May 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Mabe Stove Parts
Aug 27, 2009 | Blodgett Kitchen Ranges
Gas Safety
May 15, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
1950 Wedgewood stove safety valve instruction
maybe this might help you?
http://answers.yahoo.com/question/index?qid=20061130165913AAMHKsW
Oct 24, 2008 | Kitchen Ranges
GE STOVE MODEL JGBS15GE
Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
