Question about Hoover Platinum LiNX Cordless Stick Vacuum
Agitator brush not turning - Hoover Platinum LiNX Cordless Stick Vacuum
  • Hoover Master
  • 18,424 Answers
The belt may have come off or broke and needs replacing this link is for manual
http://hoover.com/file/344/
Posted on Jan 04, 2013
My agitator brush wont turn anymore when plugged in but I am able to turn by hand
take brush out. clean the bearings. clean all parts of the brush. probably replace the belt at the same time.
Jul 22, 2015 | Vacuums
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
Agitator wont turn
It could be one or more of a few causes. Easiest to check is the belt and/or brush roll. There are two switches for the brush roll. Both must be working properly. One is by the main power switch and the other is in the motor compartment. If the problem still persists check the brush bar motor in the power nozzle assembly
Feb 23, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Model UH70086 agitator brush won't rotate. the belt is fine and turns the wheels. replaced v belt because I thought it was stretched but new belt is the same size. everything turns, the belts and the...
The brush has to be able to rotate freely in order to work. If you remove the roller and its end caps you may find it is clogged with hair or other debris. Cleaning out the debris should allow the brush to rotate freely.
Nov 05, 2013 | Vacuums
Cant figure out how to replace belt
Hi Sylvie,
It is fairly simple to change a belt on a vacuum. I'll explain.
First, Turn the vacuum upside down with the handle in the locked position. Remove the plate on the bottom. Sometimes it's held on by screws, sometimes by clips which you should pry off with a flat blade screwdriver and sometimes you can take them off easily with your thumbs.
You should be able to see the agitator brush and belt now. Use the straight screwdriver to take the brush off. Now you can slip the belt off. Clean the inside and the agitator brush.
If you have a new belt, slip it onto the motor, then onto the end of the agitator brush making sure the belt is tight. Replace the brush and give it a sping a couple of times to make sure the belt and brush are both on properly and all are working. Put the bottom plate back on.
Hope this helps. If it does, I'd surely appreciate your vote. Thanks for visiting with us.
Handie Andie
Apr 12, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissell Healthy Home Agitator Brush Switch
you might have a bad belt ,could be stretched .but if its new i would take it back to where you bought it.it should still be under warranty
Mar 29, 2009 | Bissell Healthy Home HEPA Bagless Upright...
Agitator brush will not turn
Some of these have a resetable circuit breaker, if it has one, push it. There is a motor on the brush roll which could be bad. There also is an on/off switch, it may have a problem.Also may have a switch where the hose goes into, some models have a actuator for the switch, when the hose is pushed in, it actuates the switch so the brush roll motor turns on and stops when you pull the hose out.
Sep 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Part numbers for washers and end caps of vacuum agitator brush
The part numbers for the washers and caps can only be found if you know the agitator brush number.
Mar 28, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Hoover Z 700 Model U9145-900
Try going to hoover.com and either email them or there is a number that you can call, this is hoover direct, so someone there should be able to help you. Have your model and serial numbers and purchase date handy in case they ask. It also has a 2 year warranty on it. So if you bought it in the fall of 2006, then you have until the fall of 2008. I would take it to an warranty servicer and get it repaired before the warranty runs out.
Mar 18, 2008 | Vacuums
Hoover Platinum LiNX Cordless Stick Vacuum Logo
443 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
