Question about Conair WW60 Weightwatchers Scale
I have a weight watchers scale is reads in KG. How do I change it back to lbs.
It has always read in pounds but now it is reading in KG. Not sure how or why it changed.
SOURCE: bought w/watcher glass scales and changed battery
Incorrect in what way?
Posted on Mar 08, 2009
fitnessbalan
  • 59 Answers
SOURCE: My weight watchers scale reads ron when you tap it.
I would contact customer support here is the webpage on the site.
http://www.conair.com/-cn-18.html
Posted on Mar 21, 2009
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
  • 5 Answers
SOURCE: Changed batteries and now the scale does not read
You might wanna double check that your scale is set to the right measurement. On the bottom of the scale is a switch that allows you to choose between Kg (kilograms) or LB (pounds).
  • 5 Answers
SOURCE: The weight jumps around. If I get off the scale
You're only suppose to weigh yourself once a week. Make sure you're doing it after you've gone to the bathroom in the morning and with no clothes on. Other than that, I'd make sure the floor you set the scale on is level and that you are holding very still while weighing.
Treamill 9500hr is reading weight in pounds and not kg
Please go to the Menu, and go to the section go caractheristic and change the Lbs to Kgs.
God bless you
Jan 09, 2013 | Life Fitness 9500HR Next Generation...
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
Can not change from Kg to Lbs
Flip over the scale, on the back there is a black button, slide it to pounds.
Apr 02, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
Changed batteries and now the scale does not read correct weights. off by more than 40 lbs
Jan 18, 2010 | Conair WW60 Weightwatchers Scale
Need instructions on how to reset to show weight
how do I change scale from kg to pounds?
Mar 16, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Tanita 2204 Scale weight reading problems
Try the following steps:
1) press both the "set" and the triangle button
2) press the triangle button until you get the desired unit of measurement: a) Kilogram, b) stone lbs or c) lbs; and
3) press the "set" button.
Nov 16, 2008 | Tanita 2204 Body Fat Scale
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Conair WW60 Weightwatchers Scale Logo
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
