PPPOE connection from Dlink DWR-113 - Computers & Internet
3 Suggested Answers
  • 54 Answers
SOURCE: needed to secure my dlink dwr 655
ok...
first you need to find the default gateway of the router,u need to do this settings in the computer which is wired to the router,securing the network over a wireless connections is not suggested..
click on start,run,and type in cmd,hit enter,a black box should appear in that box type in ipconfig and hit enter,once you hit enter it will give u a lot of results check the default gateway the generic default gateway is 192.168.0.1,might be different in your case incase if you have setup in a different manner,now open an internet explorer page and remove the website name that present in the addess box,now without http or www type in the numbers,it will tell you to put in the user name and password,username is blank and password is admin (this is generic to all the delink routers provided you have not changed it earlier,if u ave changed it then put in the user name and password that you have setup,now it should open a dlink router page,now in that router page you will see an option that will says wireless,under wireless you will see an option that says security,click on security,and then under security page you will see security mode,from here you can use the security type that you want to use and then save the changes once it has saved the changes you wireless netwokr will be secured.
PS:make sure the computer is connected with a wire to the router when we are setting the security in the wireless network....
vedhick.........
Posted on Feb 23, 2009
rajendrasngh
  • 394 Answers
SOURCE: Hi, I have a dlink DIR-600
Set your Maximum Idle TIme to 0 and save the setting.
Thanks for using FixYa.
Posted on May 27, 2011
Were do i get my Password for Rooter Dlink DWR 730 3e61
Go through the manual or connect it for the first time you would get the PDF manual. Often times the initial factory password is admin or 1234.
Apr 24, 2017 | Computers & Internet
DWR-113 router, how do I change the password so others can't connect to it?
Here is the manual:
http://files.dlink.com.au/Products/DWR-113/Manuals/DWR-113_A1_Manual_v1.01(WW).pdf
Apr 27, 2014 | D-Link Computers & Internet
DWR-113 router, how to change the password so that others cannot use it?
You need to access router menu . Try 192.168.0.1 in your web browser address bar. You can really screw things up if you don't know what you are doing. Get the manual and read it 1st.
How to connect dlink dir 600l router with bsnl modem having pppoe connection
You'll need to hack it and put DD-WRT or OpenWRT on it for a decent PPPOE connection.
Sep 19, 2013 | D-Link Computers & Internet
One sim will work in the D-link DWR-730 firn but when I put in another sim that is working fine in another device, it won't work. I can log onto the d-link but you cannot get onto the web
I do have the same problem. All works fine except it stays "disconnected" and no way to change that.
Also I found no way to put or change the number to be dialled in the DWR-730 to connect to a service. Normally it needs to dial *99# for the operator I am using. I guess our problem is only that.
Who from Dlink can tell us how to access the modems dial string?
Apr 03, 2013 | D-Link Computers & Internet
Needed to secure my dlink dwr 655
ok...
vedhick.........
Feb 21, 2009 | 2wire Computers & Internet
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
