Question about Refrigerators
Amana Refrigerator Model TJ20KL Light
Light burned out; new replacement light does not work - switch problem?
peyton32034
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
  • 1314 Answers
SOURCE: Lost light Whirlpool Regal refrigerator
two ways might first un plug the unit take the bulb ou and with your finger pull up on the contact inside the light socket ***** the bulb back in and try it if that doesn't work unplug the unit and with a mall screwdriver pry out the switch un plug one wire and with a meter check it to see if its working right or just replace it
Posted on Mar 12, 2008
jumptrout51
  • 3361 Answers
SOURCE: Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
Posted on Mar 04, 2009
Maytag317
  • 1136 Answers
SOURCE: Amana refrigerator not running but light and water dispenser work
Hi, Remove the front kick plate at the bottom and locate the defrost timer box. You will see a hole and there will be a round switch you can turn. Turn in clock wise and see if the refrigerator starts.
If it starts, the timer needs changed. If it does not starts. locate the cold control (thermostat)
Check continuity on the switch. If it is the on position and the circuit is open, you need to replace it.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
Posted on Jun 14, 2009
heatman101
  • 43501 Answers
SOURCE: Amana freezer on bottom working fine, but refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
I have an Amana refrigerator door light switch part# C8967502 that is no longer being made. Is there another mfg. who makes a switch that could replace the original Amana switch Thank you Denis Subler
I'd think that any of the local appliance repair shops would have an old stock of those replacement switches. Sure, maybe Amana doesn't have them, they dump old stock, but they dump them to repair shops!
In any case, any "normally open" switch can be retrofitted, even in-frame burglar alarm contacts can be used for that application. The switch when pressed IN is open, not letting power come to the bulb. When the door opens, the switch pops out and "closes" the circuit to let power to the bulb.
You may even find on available to retrofit, at Radio Shack.
Feb 03, 2011 | Maytag Refrigerator Door Light Switch...
I HAVE AMANA FRIDGE FREEZER AND THE DOOR SWITCH IS BROKEN BUT THEY NO LONGER MAKE THE PART. ITHINK I MAY BE ABLE TO USE THE MAYTAG PART
Yes, if the maytag part fits, then it may work in the Amana refrigerator. It's just a switch that carries the current for the light bulb.
Dec 22, 2010 | Maytag Refrigerator Door Light Switch...
Broken light switch on fridge door
Any appliance parts store can get this switch.
Yes you can DIY. Take a butter knife and CAREFULLY pry the broken switch from the cabinet. Be careful not to scratch the plastic liner around the switch.
Remove the 2 wires, place them on the new switch and POP the new switch in place.
If this is a half-moon switch make sure it is installed in the correct direction.
May 24, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Mar 04, 2009 | Whirlpool Refrigerators
FILTER LIGHT WILL NOT GO BACK TO GREEN
there is usually a filter eset switch you have to push to reset the filter monitor If you will post a complete model  number for your unit I will look it up and see exactly what you have to do to reset it. on most amanas there is a switch that you hold down for 3-5 seconds that resets it.
the light does not automaticaly reset when filter is replaced. Thanks Peyton
Feb 24, 2009 | Amana 25.9 cu. ft. Side-by-Side...
Refrigerator light will not go off
How do you know it wont go out if you close the door? More than likely the light switch is bad its located in the middle at the top when you open the door.Push it in, if the light stays on see if something it blocking it, if not replace the switch.
Feb 17, 2009 | Amana 22.6 cu. ft. Side-By-Side...
HELP MY LIGHT DOES NOT WORK AND MY WIFE HAS CUT ME OFF UNTIL IT DOES
The problem is in the control board. A diode is shorting the relay, also has burned off trace. Looking for diode to replace as I write this.
Jan 01, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
