Question about Kenmore Washing Machines
Manual for 417.29052991
Manual for front end loader washer model 417.290522991
  • 1294 Answers
SOURCE: Eurotech MA66 front loader user manual
Click on washing machines (below FIXYA )on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Posted on Feb 08, 2008
SOURCE: my front end loader washer
E10- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
Usually due to debris trapped in the drain pump (pebbles/coins/hairgrips etc) jamming it. Clean it all out including all pipes.
Please rate fixya if we could solve your problem.thank you.
Posted on Dec 11, 2008
SOURCE: GE front Loader Washer Door
the following link might help you out.Please do post your comments.
http://www.repairclinic.com/Parts?s=t-WBVH6240FWW+-%3d%3dc226&n=1&z=10
Posted on Dec 23, 2008
  • 14 Answers
SOURCE: washer will not spin
I have thata probelm a lot too. I have read that the controls don't sense that the door fully shut. You might try slamming it shut, jiggling the door, poking in the hole where the latch goes. When mine won;t spin, slamming and jiggling works.
Posted on Jan 24, 2010
Jahn27
  • 1554 Answers
SOURCE: frigidaire frontend washer LTF2140ES3 will drain not spin
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle to advance to the spin cycle. When the machine works except advancing to the spin cycle, it signifies that this auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to fix the washer.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the wires from its terminals then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Mar 10, 2010
I have a Whirlpool Duet front loader Washer approximately 6 years old. The control lock is on and I can't start the washer. How do I resolve this problem.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a model 417-44042400 front loader. I
See the following site for Sears manuals for your washer:
They are PDF files that can be downloaded and printed.
http://www.managemylife.com/mmh/owner_manuals/search?query=417.44042400
Apr 05, 2010 | Kenmore 44042 Front Load Washer
Maytage neptune front loading washingmachine, display is flashing "nd" can you tell me what that means? I cannot find my owner's manual
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.##@@@@
Feb 15, 2010 | Maytag Neptune MAH6500A Front Load Washer
I have a whirlpool duet front end loaded washer that has a controlled locked light that is illuminated. what is wrong and what should I do
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My HE5t front loader not powering on
Sep 10, 2009 | Kenmore Washing Machines
Kenmore HE4T Front loader control lock indicator light is on and will not let me use any other controls.
Sep 05, 2009 | Kenmore Washing Machines
Kenmore front loader Model 48102 will not start
Mar 14, 2009 | Kenmore Washing Machines
Kenmore washer 110.45981 400
Hold down 'end of cycle' for 3 seconds. Power shd be on.
Feb 09, 2009 | Kenmore Elite 45986 Front Load Washer
How do I get a repair manual for my Kenmore front loader
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Dec 04, 2008 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Front loader
Click on Frigidaire (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
If u are not satisfied with the manual, click on 'thanks for trying', your prob will be back on the website.
Jan 15, 2008 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
