Question about Datamax DMX I-4206 Printer
Ribbon Fault Error Message is Ribbon Fault. I have it threaded properly. Is the ribbon bad or is it the labels?
  • dbuscher Jan 30, 2009
    I keep getting a ribbon fault, i have tried a new ribbon and roll of labels and have installed a new print head and the error will not go away.
SOURCE: "warning Ribbon In" error message
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a link to a picture of where the sensor is located: https://support.zebra.com/cpws/docs/xi3plus/140xi3plus/images/140xi3p021.jpg
I hope this helps!
Posted on May 13, 2008
SOURCE: Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Posted on Aug 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Printer Ribbon has a wrinkle in it
Remove the ribbon and try to remove the crease. Check the printhead for obstructions. You may have to open up both halves of the ribbon cartridge to look for jams or obstructions.
Astinsan
  • 87 Answers
SOURCE: Thermal Ribbon has a wrinkle
The thermal print head is damaged. You can try to clean it with a thermal printer head cleaner. That will only help if it is just clogged up with thermal print ink.
Posted on Nov 22, 2008
bistek
  • 19 Answers
SOURCE: Error conditon ribbon out
if you are not using a ribbon you should configure your printer properties in direct thermal the same with your printer configuration in LCD Panel, if your printer properties is different with the LCD Panel error condition ribbon out will come out to your LCD Panel
Posted on Dec 01, 2008
I HAV A DATAMAX I-CLASS PRINTER IT IS SAYING THAT I HAVE A RIBBON FAULT AND THE PRINTER IS THERMAL
Thermal can mean "Direct Thermal" (no ribbon) or "Thermal Transfer" (with ribbon). If you want to print using Direct Thermal labels you need to select Direct Thermal from Media Settings in the Menu accessed from the Control Panel on the front of the printer. Otherwise, the printer sensors will look for a ribbon that is not there, and you will see an error message.
Feb 16, 2015 | Datamax I-4208 Thermal Label Printer
I have a Zebra 105 SL, I have the ribbon installed but the printer tells me that the ribbon is out. I've tried changing the ribbon and labels out but as soon as I power it back up and try printing again...
Calibrate the printer from the setup menu.
You'll (1) Load the label backing with the ribbon (2) remove the ribbon - just shove it to the right, out of the way of the ribbon sensor (3) reload the label and ribbon.
The printer will run a number of labels out.
Feb 16, 2011 | Zebra 105SL Thermal Label Printer
Error message: Ribbon out keeps displaying when there is a fresh roll in the spool, checked everything I could see and find nothing Possible bad sensor?
Check that the metal ribbon blade spindles are in place. these hold the ribbon core in place.Also make sure the ribbon is not loaded over the ribbon reflective plate.( under the head mech where the label guide slot is) Try a manual calibration in the menu.If it asks for a password, its :1234. There could be a slack or broken belt. just fyi: there are (four / 4) belts. The ribbon motors rarely go bad, if all else fails , its probably a ribbon control board.Also check that there is not any junk stuck on the ribbon/ auxiliary roller gear. Sometimes toggle pressure is the culprit.If there is not enough pressure on the head plate, sometimes it will slip.
Jan 21, 2011 | Zebra 110PAX4 Thermal Label Printer Print...
Warning Error Ribbon In message is being displayed on screen regularly. What can be a proper reason of it?
if use ribbon, change the seting DIRECT-TERMAL to TERMAL TRANSFER, or run manual calibratio and sensor profile, save, turn off the printer, and on again.
Nov 10, 2010 | Zebra Z4Mplus Label Printer
Attempting to print labels from a Monarch 9855 printer and receiving error message: "Print Head error 768." Printer was working fine as of last Friday. We have other Monarch 9855 printers that are on other...
the problem is your printhead is bad . do a print test by presing both arrow buttons at tah esame time for two seconds, look fo rthe line that reads bad dots. if the value i sgreater than 000 yu have a bad printhead
jay
Jun 08, 2009 | Monarch Paxar? 9855 Label Printer
Ribbon Error, ribbon roll seems sloppy
I hope this information will help. If you have the manual, can you check and make sure that the ribbon is threaded through the right path. If it's not, there won't be enough tension on the ribbon and the ribbon will get sloppy as you use it. If my information was helpful, please rate it. Thanks for using FixYa.com
Dec 04, 2008 | Toshiba TEC B-472 Thermal Label Printer
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Printer Stripe S-500 Zebra
Question, when the printer prints is there an image of the data on the ribbon when it spools onto the ribbon takeup spool? If so, the ribbon may be installed backwards. I'm sure you know what you are doing but one must check even the smallest detail when trying to solve these strange problems. If the ribbon is installed correctly and there is no image of the data on the ribbon you may be dealing with a bad printhead and the printhead needs to be replaced.
Dec 19, 2007 | Zebra Stripe S500 Thermal Label Printer
Datamax DMX I-4206 Printer Logo
599 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
