Question about Beretta Water Heaters
How do I leave the water heater when I go away for the winter
We are leaving our apartment for the winter and I need to find out what setting to leave our water heater on. The water heater heats our water as well as provides heating for the apartment (radiant floor water heating). Do we turn the heater off? Do we simply lower the set temperature to something low (5 degrees or so). Do we turn off the water supply to the apartment? The water heater is located outside of the apartment in a room that is not insulated (temperature there could drop below zero). If we shut off the water to the apartment will that affect the water heater if we leave it on (set for 5 degrees or so)?... Meaning, does the water heater need continuous water supply to run the heating or is it a "closed" system? Any insight into this issue would help. Thank you.
  • Beretta Master
  • 3,315 Answers
If you leave the heating on low to stop freezing is fine . Not sure how you water works but I would leave it on to stop freezing Also get some one to pop in once a week to check things are ok .
Posted on Mar 21, 2017
  • 68 Answers
SOURCE: Is it normal for my electric hot water heater to "sweat"?
could be a pin hole leak some where on the tank and the insulation is absorbing it for now if it is older then 6 years and u havent replaced the anode rod or flushed the tank once a year you should probibly look to replace it
Posted on Mar 15, 2009
  • 63 Answers
SOURCE: A.O.Smith water heater relief valve letting out water
You just need a new pop off valve $10-$15 dollars. Unscrew the old one on top of the heater, put some teflon tape on the new one and screw it in place. Being that the house is for sale I would probably have a licensed plumber do it just to protect my self from any liability. Also most state codes require that pipe to terminate in a floor drain, most home inspectors will catch that. If it doesn't I would have him do that also.
Hope this helps-please rate
Posted on Mar 17, 2009
gary1121
  • 332 Answers
SOURCE: Whirlpool Energy Smart water heater not hot
I think some one mis informed you, the normal temp on any water heater from the factory is 120, it should not go above that for reasons of sevear burns, as far as it't smart part it's just a name, you will lose a couple of degrees just comming torm the tank to the faucets, the water heater will allways keep the temp in the tank at what ever it is set at, it doesn't have the brains or computer to know what time of day it is but when the cold water comes in to the tank it comes thru a dip tube that goes to aprox 1 inch from the bottom of the tank, if you take a long shower and do not have a energy efficant shower head you can use up to 5 gals, per min of hot water where an energy efficant one only uses 2.5 or less and still has the same pressure at the shower head, the temp in your water heater tries to stay at the setting it is at depending on how much is used at one time meaning washing machine, filling tub or dishwasher at the same time, it lets more cold in as the hot goes out and as you know it can only heat up so much at a time and the cold water is just going across the bottom of the tank, so the name is just that no diffrent then any other water heater unless you went to a tankless water heater.
Posted on May 29, 2009
gary1121
  • 332 Answers
SOURCE: when filling bathtub or running two showers, water heater howls
it could be the fact thath the water comming in is what the problem is,, on a well system the water is extra cold and the unit is working hard and with sand aso comming in it makes it harder to keep the temp up on the water,,, flush the tank, put hose on it and open the drin valve with a hose on it turn the cold water on and let it flow till the water comes out clear usually about 5 min,,, get all the sand out and other debris and try it
Posted on Jun 06, 2009
rick_stokes_
  • 61 Answers
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Posted on Sep 19, 2009
Want to shut off my hotwater heater and still run my boilerhave base board heat
Turn off water but leave heat on - Possible? - Handyman WIRE ...
handymanwire.com > ... > Heating and Air Conditioning
Jan 14, 2003 - 10 posts
My hot water baseboard heating system is a closed system. ... Could I shut off the main water and leave the boiler and heat going for ... If one is not installed, install one and rely on that to save the boiler from the damage of running out of ... I do not wantto have city water push my antifreeze out of the system ...
What's the best temperature to set my hot water baseboard ...
greenhomeguide.com/.../whats-the-best-temperature-to-set-my-hot-water...
Nov 21, 2010 - With hot water baseboard heating, is it better to keep the heat at 60+ degrees ... a hot water heating system where water is heated in a hot water boiler and then ... by setting the thermostat to lower the heat when you don't need it on. ... Not only do I turn my heat down when I leave for work in the am but also ...
Jan 17, 2016 | Water Heaters
Boiler on hot water radiator system wont work
This is both a complex and dangerous system. There are many factors which can cause this. I will need more information. I will ask some basic questions... Was the thermostat changed out with the a/c unit or does it have a separate one? Did the gas valve get shut off? Did the breaker get shut off? Is the water on? They have low water lockouts. 99% of the time, it is where work was done. Did they hook up the stat correctly and establish the proper type of heat on the stat? Is the circulation pump on? Is the flame control board reset tripped? Leave feedback and we can go from there.
Nov 13, 2013 | Water Heaters
Water heater is not working after a power outage
it is possible it needs a reset. 1. turn off the breaker to make sure there is no power to the unit 2. open the top cover and there will be a red button like this http://www.tonyhoover.com/wp-content/uploads/2010/03/water-heater-upper-thermostat.jpg push it. It may have a plastic cover over or around it, leave this in place it is insulation for the wiring.
close it up carefully and then turn on the power and see what happens.
Aug 13, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
What is the top thermostat supposed to be set at
As a general rule, thermostats are set to 120 for optimal heating/energy-conservation.
If household uses more hot water, then move upper thermostat to 135 for example, and leave lower thermostat at 120.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 02, 2011 | Water Rheem MR40245 Marathon Electric ...
How much clearance do i need to leave on top of the water heater between the insulation and the chimmney? is the insulation fireproof?
Gas or electric?
1) Electric heater can be completely covered with insulation except TP valve. Set electric heater on insulated surface. Insulate pipes completely right down to tank.
2) Gas heater is different.
No insulation over combustion area, or gas valve, or air inlet or. No insulation on top of tank that will interfere with venting of dangerous combustion products including odorless CO gas. Foam insulation on pipes should stop 10" short of tank top. No insulation within 6" of the 3-4" inch galvanized vent pipe.
Here's photo with gas water heater insulation tips:
http://waterheatertimer.org/images/Insulate-gas-water-heater.jpg
3) Tankless gas. No insulation on box. No pipe insulation within 12". No insulation near vent pipe.
4) How much clearance between heater and chimney?? Not sure what that means. Is that the water heater vent stack? Or where vent stack goes into chimney stack? No insulation on gas flue pipes. Or within 6 inches of 3-4" water heater vent pipes
5) Is insulation fireproof? Everything burns if it's hot enough. If you throw insulation into backyard fire, paper and foil will burn away and insulation kind of falls apart in the heat. Fiberglass insulation cannot be set on fire with a match. Foam pipe insulation will burn.
Dec 02, 2010 | Thermwell Water Heater Blanket
The water heater is broken. When I set it to come on at a certain time both needles stop at 6:30 position (not time) and then the water would get hot when it feels like and does not stay hot long...
Let's make sure that you have these set correctly first. There is a on tripper (normally silver) and a off tripper (normally brass) that will be the only trippers that you will have unless you have the heater coming on twice a day. And then you have the pointer for the cureent time of day. Make sure that your time is set and trippers are set for time on and off. It's sounds like the two trippers right now are beside each other and that is why it is coming on and then right back off. You would need to leave the heater on for at least three or four hours to get it the whole tank hot enough for a couple of people to take showers and not lose hot water,
Sep 30, 2010 | Intermatic WH40 - Water Heater Time Switch...
Water Heaters Logo
55 people viewed this question
Top Beretta Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Beretta Water Heater Expert? Answer questions, earn points and help others
