Question about Radio Communications
SAMSUNG GT C3010S BLUETOOTH HEADSET PIN CODE - Radio Communications
2 Suggested Answers
SOURCE: pin code
set up your phone to search for BT devices, press and hold the phone button on your Skywing or H700, once the purple light comes on open the boom. Your phone should see the device. When prompted for a passcode enter 4 zeros, if that doesn't work, try 5 zeros, if still no luck try 1234 and 12345
Posted on May 09, 2008
I am not able to pair my nokia bh-503 with my samsung galaxy ace. Please help me.
Try to put your headset in pairing mode first. Starting with it turned off, press and hold the multifunction key until the indicator light is flashing quickly in blue. Then, bring your phone and headset close to each other, and, on the phone, go to 'Menu > Settings > Wireless & network' and check the 'Bluetooth' checkbox. Then, tap 'Bluetooth settings > Scan for devices'. After a little while, your headset should appear on the bottom of the screen. Tap over it to make it pair. If a pairing code (or PIN or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is successful, your headset should enter the stand-by mode. It should appear in the paired devices list on your phone as connected. If you tap and hold over it and tap 'Options', you will be able to select your headset services.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can assist you any further.
Regards, Carlos
Sep 14, 2011 | Nokia BH-503 Bluetooth Headset
Need pin code
Bluetooth pin numbers can be any four digit number you like as long as you input the same four digit number into both the headset and the phone ie 1234 or 0000 when you are pairing them together
Apr 28, 2011 | Samsung HKT450 Bluetooth Headset
I have two bluetooth enabled phones that I would like to get paired. The first one is a Samsung Galaxy Tab and the other is Nokia 2630. I would like to use the SGT's A2DP / Call and have the Nokia on...
Sure! If your headset has never been paired to another device before, just by turning it on, it should enter the pairing mode, denoted by its indicator light steadily lit in blue. Otherwise, starting with it turned off, press and hold the answer/end key some seconds beyond the point to turn it on. Release the key only when you notice the indicator light steadily lit in blue. Now, first on your Galaxy Tab, go to 'Menu > Settings > Wireless & network > Bluetooth settings' and tick the 'Bluetooth' checkbox to turn it on. Then, tap 'Scan devices'. After a little while, your headset should appear in the list of paired devices. If needed, slide your finger to find your headset in that list. Tap it to start the pairing process. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You will be prompted to choose the bluetooth services you want, i.e. phone and media. Of course you can come back to these settings whenever you want, in order to activate or deactive these services. Now untick the 'Bluetooth' checkbox to turn it off, in order to pair your headset with your Nokia phone.
Then, turn your headset off and press and hold the answer/end button to put it in paring mode again. Now, on your Nokia, go to 'Menu > Settings > Connectivity > Bluetooth' and select 'Bluetooth > On'. Then, select 'Search for audio enhancements'. After a while, your headset should appear. Select it and make it connect. Again, if a pairing code (or PIN, or passkey) is requested, enter '0000' (four zenros).
Your headset will be able to handle both your Galaxy tab and your Nokia phone at the same time. it is already connected to your Nokia phone. Go back to your Galaxy tab, and tick the 'Bluetooth' checkbox again to turn it on. You should see the bluetooth icon light in blue in the notification area.
By the way, your headset's user guide can be found here, your Galaxy Tab's here, and your Nokia phone's here.
Hope you are able to sort your problems out soon.]
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Apr 02, 2011 | Jabra BT3030 Wireless Headset
Hi, I have purchased Samsung Galaxy ACE S5830 whether it is possible to connect Samsung Bluetooth Headset WEP 450. Kindly inform me how to do it.
1 Enter Pairing mode. • Turn off your headset and press and hold the talk button until the blue indicator light remains lit after blinking. • If you turn it on for the first time, it proceeds into Pairing mode immediately.
2 Search for and pair with your phone --> turn on the bluetooth with the widget on the home screen or in the settings. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will flash 10 times rapidly before entering Standby mode. • If the blue indicator light remains lit, retry pairing.
Mar 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
I has sony ericsson blue tooth, my phone is nokia E72 how to connect?
By sony ericsson blue tooth i think you mentioned the headset. If you got the manuals for that headset, just check for the default pin code for the headset. But if not try these pin codes such as 1111 or 0000 or 1234 etc.
To Connect:
1. goto connectivity in ur mobile nokia e72. you will find it as a seperate icon in your menu, or you can get it from setting/connectivity.
2.in that switch blue tooth on.
3. now go to the next tab, and select options. from that select new paired device.
4. Now it will find the blue tooth headset. If it didnt detect, make sure your bluetooth headset is switched on.
5. then select that headset fro the search result and then it will ask for confirmation with the pic code.
type the pin code you hv gt from the manual or try these(1111 or 0000 or 1234 etc.). then it will accept. If its accepted, the bluetooth headset will start working!
Thanks, ask me if u gt any doubts.
Oct 06, 2010 | Cell Phones
I have forgot samsung gt-c3010s security code
hi
just start the phone without the sim, and when it says insert sim
just type
*2767*2878#
or
*2767*3855#
WARNING
WILL RESET ALL YOUR PHONE SETTINGS TO FACTORY
If this was helpful, write me a good review
NICK
Sep 07, 2010 | Samsung Cell Phones
Can i pair my new iphone with a used plantronics 220
Yes, sure. Begin with the headset turned off. Then, press and hold the multifunction button until the blue and led lights flash alternately. The headset is in pairing mode. Now, make your iPhone's bluetooth application ('Home screen > Settings > General > Bluetooth') search for new devices. After a while, the heaset will appean on the phone screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is resquested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Forgot the code
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jun 14, 2009 | Motorola Mobility H350 Wireless Headset
Pin code
Is this the first time you are pairing two Bletooth devices ? Is the security pin for your Samsung phone '0000' ? Usually, the code you have to enter on your phone to pair it with a Bluetooth headset or headphones is '0000' (the number 'zero' 4 times), unless Jensen's Bluetooth headphones use a different pin.
Hope this helps.
zeceten@yahoo.com
Dec 22, 2007 | Audiovox WBT212 Headphones
Radio Communications Logo
42 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
