Question about Packard Bell Computers & Internet
Can't boot my parkard bell,it says bootmgr is missing
Cannot boot.
blackberries
  • 80 Answers
SOURCE: ibm think pad model z60t won't boot up says BootMgr missing
registry error try downloading glary utilities ! its a free registry fixer!
Posted on Feb 26, 2009
SOURCE: BOOTMGR is missing
Bootmgr file missing
The system Post unable to proceed due to a defective Drive.
I corrected that same problem in less than 15 minute.
You are unable to boot,the error message comes up .
Bootmgr file missing ; > press ctrl alt del .
This is what I did ..I enter the BIOS I set the boot order.
(1) 1st Floppy 2nd CD ROM 3rd HDD
(2) I replace the DVD Drive with a new DVD Drive
(3) I put Gos Linux operating CD in the DVD drive
(4) I then boot the system.
(5) All went well, I format and install........
From ; mjsullkeys@hotmail.com
Posted on Apr 10, 2010
  • 1705 Answers
SOURCE: parkard bell easynote tj 65
I don't know what country you're in so its best to google parkard bell support and follow their links for support and downloads.
The user manual is availble for free download as a zip file.
http://www.packardbell.com/index.html
Posted on Oct 29, 2010
  • 1542 Answers
SOURCE: laptop not working Packard bell
HI
I Think the laptop is trying to read the hard drive to boot up and its got a problem reading it
it may be worth turning off the laptop unplug the power core remove the hard drive from the base of the laptop usually only one or two screws to take off the cover and normally quite easy to remove
then try to start up the laptop
then turn off again
give the hard drive a quick blow over the connections
replace the hard drive
and try to boot up again
if this dont help
press power up key as well as the F8 key
this will hopefully take you into the repair options
and try the last good known configuration
or
repair my computer
if this does not work then the hard drive may be corrupt of dead
which is not good new if you havent done any backup disks or have any recovery disks
or a operating system install disk
hope you get it sorted
Posted on Jul 07, 2011
  • 112 Answers
SOURCE: How can i boot my
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
Posted on Aug 07, 2011
Missing boot manager and blue on everything
if you boot pressing F8 can you get to the repair option?
Nov 27, 2012 | Computers & Internet
Bootmgr is missing
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
Sep 10, 2012 | Acer TravelMate 8371 Timeline (LXTTD03077)...
PC will not boot, BOOTMGR is missing. What do I need to do?
I assume it's Windows 7.
Check that the BIOS is set to boot from CD/DVD as the first boot device and then put the Windows installation disk into the drive. If done correctly then the PC should boot from the CD/DVD and then just follow the on screen instructions (follow the instructions and select the repair option).
Jun 08, 2012 | Computers & Internet
Bootmgr is missing
I don't work in a lab anymore but when I did (in XP/2000 days) this apparently is the equivalent of the 'NTLDR not found' error, which was always bad... you would have to go in through recovery console to repair it. Evidently the BOOTMGR is the new NTLDR, so your going to have to repair the OS. Check out these links I found, and good luck!
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
Jan 12, 2012 | Computers & Internet
Bootmgr is missing how do i resolve this
I'm assuming you're using Windows 7? Well this is a fairly common problem. You need to create a recovery media DVD. There's a great guide on how to fix this problem. Here's the link: http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
I hope this helps!
Aug 26, 2011 | Toshiba satellite c660
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
Aug 07, 2011 | Computers & Internet
My laptop says bootmgr is missing and i dont know how to fix
First make sure that all usb devices are unplugged and remove all cd's or dvd's or sd cards etc.
If you are running Windows 7 or Vista you can try do a repair by hitting F8 while it boots and then select repair. If this does not work you will need a install disc. If you have Windows XP you will need an install CD to do a repair. I have attached a few links that may help explain in detail. Thanks for using fixya.
bootmgr-is-missing-error-while-trying-to-boot-windows-vista/">http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
May 15, 2011 | Acer Aspire 3050-1733 Notebook
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
Parkard bell easynote tj 65 manual
Oct 29, 2010 | Computers & Internet
Parkard bell g1350 easynote. not booting up fully gets as far as the splash screen and then stalls.
try to boot in safe mode if you can otherwise you have to reinstall the operating system
Jul 29, 2008 | Packard Bell Computers & Internet
Computers & Internet Logo
20 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
