Question about HP LaserJet M4345 MultiFunction Printer
Hi, when fax, is the paper face up or face down
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Should be face up.
Posted on Jan 19, 2009
Hi do i fax with the paper facing up or down?
not sure about this specific model. However, on the loading platen you should see a diagram of a sheet of paper with the top right corner turned over which indicates the paper should be face down. If it doesn't have this diagram you should assume it is face up.
Jul 22, 2011 | Brother MFC-3220C Plain Paper Inkjet Fax
Do I insert the paper I want to fax face up or face down?
Having no Operating Guide, I'd type a one line sample, make a note on the paper like "face-up" and put it in with the paper facing up and hit "print".
If it prints on that side you have your answer. If it prints on the backside, then put your papers in facing down.
Jun 20, 2011 | Lexmark F4270 Plain Paper Inkjet Fax
Do I put the paper face down or face up when i Fax?
Hi!
Face up please. Since scanner part of device is just behind dial pads.
Hope this helps. Cheers!
Mar 12, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
How do u load paper? front or back side up?
Hi, It dosen`t matter how you load paper, Copy paper are blank on both side, now if you are reusing paper with prints on one side then you do it by trial and error.
Now if you meant how to load document on top, then that`s a different story, most fax machines require that you put the document face down. I would suggest that you make a copy from a document face down and if it comes out ok, fine, if the copy comes out blank then you need to put the document face up instead.
Hope this helps.
Mar 13, 2010 | HP 1040 Plain Paper Inkjet Fax
Fax, Copier, Scanner and Printer #4540
thank you for choosing Fixya.com.
sending the document using fax machine always remember that the proper position is to face down the documents,
hope i help you on this matter.
please don't forget to rate our answers properly.
Feb 23, 2009 | HP Easy Refill Kit for (HP) Color Inkjet...
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Help
Most faxes are face down. check the symbol on the paper input, there is a symbol of a paper with the left corner bent. This means face down
Dec 12, 2007 | HP 920 Plain Paper Fax
HP LaserJet M4345 MultiFunction Printer Logo
51 people viewed this question
Ben Johnson
