Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Have replaced the silicone seal on the Krups XP 4020 espresso machine but leaks (steam & coffee) still especially withe the ESE pod filter basket. Any special care to be taken while replacing the
LEAKING SEAL/GASKET KRUPS ESPRESSO XP4020
5 Suggested Answers
  • 3 Answers
SOURCE: Krups xp 4020 leaking
http://cerinicoffee.com/Saeco_parts_diagram.asp
Posted on Mar 14, 2008
  • 4 Answers
SOURCE: Steam still coming through brew group even when pump not ON
I posted response and solution to similar issue see post below and comments :
YOU NEED TO LET MACHINE COOL OFF AFTER YOU TURN IT OFF OUCH!!
You can release pressure placing a cup under steam wand open slowly and partially while machine is OFF and let hiss out slowly. Then open cup slowly if you have to force it open DON'T. That PUCK sound can make you afraid of your machine can't it. I wont admit I haven't done that four or five times.
posted by bronwenmair on Jul 08, 2008 Report abuse
We have a Saeco Classico that worked very well when we first got the machine. Now the coffee is bitter and there is no crema in the shot at all. We tried changing grinds and tamping, nothing seems to work. Can you help? Thanks so much. We miss our morning coffee :-)
Posted on Feb 17, 2009
  • 10 Answers
SOURCE: We just got a Via Venezia espresso maker. When I
put the rubber gasket in, then the pod basket, then the pod
Posted on Aug 02, 2009
EsWorld
  • 1618 Answers
SOURCE: coffee pod holder began leaking when brewing
Replace the group gasket.
Posted on Feb 21, 2010
I cant get my Gaggia Classic to work with pods
You need to use the single-serving size one-hole basket, not the double, with the diffuser valve seated beneath the basket. Then the Illy ese pod should be inserted with the decal facing up. Finally, and most importantly, when you lock the filter assembly into the machine, you need to close it firmly. Brown water can mean that the basket assembly is not sealed in tight enough.
Sep 07, 2014 | Gaggia Classic Espresso Machine
I have a Gaggia classic and want to use pods. I've got Illy ese pods and the right (one hole pressurised basket) but still get just brown water. Can anyone help please?
I HAVE BEEN USING THE GAGGIA CLASSIC FOR 34 YEARS AND I ALWAYS BELIEVED THIS MACHINE IS BEING DESIGNED FOR SPECIFIC COFFEE QUALITY. THE ILLY ESE PODS ARE NOT FOR THIS MACHINE, TRY LAVAZZA PODS INSTEAD THAT IS SHAPED PERFECTLY WITH GAGGIA FILTER HOLDER FOR PODS.
My Krups XP4000 coffee machine gasket split. I have descaled the machine and replaced the gasket but water still sprays out of the side of the head and occasionally blows past the gasket. I replaced the...
I had the same problem .... My gasket split and I replaced it and water was still leaking past the gasket... Try this - Don't tighten the screen screw all the way...I have mine set at about 6 turns counterclockwise from fully tightened. Loosen the screen screw more if needed until the leaking stops... As a result, the gasket will sit lower and make a better seal with the portafilter lip.
Feb 17, 2011 | Krups XP 4000 Espresso Machine
Where can I order a krups xp series seal MS-0A01503? It is a seal for the plunger that expels the coffee cake after brewing. It started to leak and I need to replace it.
Nelson Appliance has this: http://goo.gl/bsjqj. I think this is what you are looking for. The description they give is: Boiler center gasket / seal #MS-5015004 for use with Krups XP7000 series espresso machines.
Aug 31, 2010 | Krups Coffee Makers & Espresso Machines
The hard plastic gasket that fits 1/2 of the seal has fallen off - I can manually put it back in place each time I make espresso, but it doesn't always stay in place. How can I get a replacement?
Here is the contact info for the authorized Krups parts vendor. I was not able to locate the exact part as the number off the bottom of the machine is required. They should have no problem getting you a new gasket. Hope this helped some:)
Aug 27, 2010 | Krups Espresso Novo 2100
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
145 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
