Question about Kenwood KW85 Air Conditioner
Moved into new house need set of instructions
Instructions for dishwasher kdw243a
    Scholar:
  • 144 Answers
Try this. I'm not sure if it applies to your model.
The reset sequence used is:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Posted on Jan 19, 2009
My dishwasher is not enough with water at the start of the cleaning cycle
My new DW had the same problem but when I had a tech come to the house he explained that the DW only uses .8 gallons of water and that what I am seeing is normal. Do your dishes come out clean? My did, so I guess he was right. Good Luck...xo
Sep 20, 2014 | Kenwood KDW243A Builtin Dishwasher
Kenwood KDW243A - It blew the circuit breaker.
hi it probably the heater element had a similar problem on ours.
Oct 26, 2012 | Kenwood KDW243A Builtin Dishwasher
My Kenwood KDW243A built in dishwasher is desplaying what I assume is an error code, E3. What does this mean? The washer is not washing properly.
E3 means the base is full of water. A quick fix is to tilt the machine back for 10 mins or so but you need to find the cause of the leak and repair it
Jun 03, 2010 | Kenwood KDW243A Builtin Dishwasher
SHOWING E3 ON DISHWASHER
Had the same problem (apart from the code) and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Apr 13, 2010 | Kenwood KDW243A Builtin Dishwasher
Dishwasher not working
try pot&pan setting.
Jul 15, 2009 | Dishwashers
E1 fault on kenwood dishwasher kdw243a
error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
Jan 18, 2009 | Kenwood KW85 Air Conditioner
Kenwood kdw243a
The dishwasher still has water in it.  Lean dishwasher back at least 45 degrees and water should drain out through overflow pipe.  It could be caused by the dishwasher not being level.  Otherwise from reading reviews online it seems to be a common fault with this dishwasher and lots of people have returned and purchased different.
Sep 28, 2008 | Dishwashers
Kenwood dishwasher kdw243a
kdw243a code E3 what doesthis mean. ??? pleae.. adres Poland,,,,,, e_mail wiesiekwro@poczta.fm
Dec 14, 2007 | Kenmore Dishwashers
Kenwood KW85 Air Conditioner Logo
250 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
