Question about Typhoon Vacuums
I need replacement water filter for my Typhoon SC-397 Steam Cleaner
The cleaner says I should replace water filter when "puce" ... well it has what i call perished and I cannot find any outlet which sells these?
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
  • 37 Answers
SOURCE: HOW DO I CHANGE THE BELTS ON A BISSELL STEAM CLEANER
on your housing you will see a plastic cover adout 4 inches long remove this piece and you should see where your pump belt goes. flip your steamer over and remove the little red retainer that sits by the belt you have located. at this point you can take your brushroll out and slip the pump belt over the pump and onto your motor. then reassemble.
Posted on Sep 27, 2008
  • 92 Answers
SOURCE: Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
Posted on Jul 29, 2009
  • 60 Answers
SOURCE: My Bissell ProHeat steam cleaner won't spray water. The accessory
Under the plastic under the water tank (its a pain to pull apart to get to it) there is a solenoid that actuates the water between the floor and the tools. This is toast if its not spraying the floor, its simply not reacting to the signal to let it go through to the water side.
Seems to be a common problem with the Bissell Proheats. You can order a new one online for about $12 and try to get to it to replace it yourself (if you can open up the base its obvious which part it is if you just follow the hoses).
Posted on Oct 31, 2009
  • 20 Answers
SOURCE: My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Posted on Apr 30, 2010
How to clean filters for dyson vacuum cleaner
Hi Seema, it's Jack at Dyson.
DC27 Total Clean has two filters, engineered to last the lifetime of the machine in normal use. These should be washed at least once every 3 months using cold water without detergent, as shown in the video below. Allow at least 24 hours for both filters to dry completely before replacing them.
I hope this helps, but if you'd like any further guidance you're welcome to contact us directly by calling 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Sep 08, 2014 | Dyson DC27 Total Clean Vacuum Cleaner
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    I have the SAMSUNG WA80V3 washing machine and I have tried many detergents but they all clogg. I also put a filter but still the problem remains. Is it the water quality? I live in Oman.
    see the causes and fix it. God bless you
    stopped spraying. If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly from
  • Sep 22, 2012 | Samsung CASE-DETERGENT;WA80V3 -...
    I need the attachments
    I have attachments for the SC 505 Euro-Pro Shark Portable Steam Cleaner. My cap broke off of the water tank and I can't find one to replace it so I'm trying to sell off the pieces. Email me at rbvasanj@yahoo.com and let me know which ones you want. This is what I have. We can work out a price.
    1. Nylon Detail Brush (x2)
    2. Angle Concentrator/Brush Adapter
    3.Extension Tubes (x2)
    4.Window Squeegee
    5.Floor Brush
    6. Filling Flask
    7. Shoulder Strap
    May 05, 2011 | Euro-Pro Shark SC-505 Handheld Steam...
    Safety cap on the Euro-Pro dexuxe steam cleaner style SC507H
    if it is anything like mine...you push the cap down, give it a full turn & release. keep doing this (maybe 5 or more times, and eventually it will start unscrewing easily without needing to push down
    Oct 24, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
    Euro-pro shark steam cleanercs618hd
    I am looking for an operator's manual for the Euro-Pro Schar SC-505 Handheld Steam Cleaner.
    Any ideas?
    May 26, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
    Euro-Pro Shark hand held steam cleaner model #sc618hd
    Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
    Need to access an owners manual for my euro pro steam cleaner model # SC505H
    I have the manual scanned. Send me your email address and I will send it to you. I can't post it in this forum.
    wilhouse
    mwilhousel@hotmail.com
    Apr 09, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
    Vacuums Logo
    134 people viewed this question
    Top Typhoon Vacuums Experts
    JoeVacs
    Are you a Typhoon Vacuum Expert? Answer questions, earn points and help others
