Question about Ovens
Circut Board Replacement
Is this something I can do myself? I have quite a bit of do it yourself experience but not much with electronics.
  • aussiemic711 Jan 19, 2009
    I do not have the luxuary of having a qualified service person repair the appliance as I said I live in Mexico and there are no Whirlpool service people here that will work on Microwave Ovens. Is it something I could do my self with guidance from a professional?
    President:
  • 1,990 Answers
I would Definately have a Pro repair this Board. There are Numerous Things that could go wrong that would need Immediate Attention at the Time.
Posted on Jan 19, 2009
  • Travis Humphries
    Travis Humphries Jan 19, 2009
    Yes if you can Locate the Parts for the Repair. There are a Number of Places on the Net to find Parts. Check Radio Shack First.
How can I find a replacement touchpad part that appears to be out of production?
Hello Joe;
My name is Peter. I am a retired field service appliance technician. I have checked all of my sources for your touch pad.
There is a company that remanufacturers control boards. I do not know about touch pads. See below.
Be careful about touching your control board. Ground yourself by touching something that is bare metal. Static electricity will knock out a control board. All Brands Appliance Parts Repair Service CoreCentric Solutions
Jul 02, 2014 | KitchenAid Ovens
Oven
We had a 1980's wall type oven that would not control the heat any longer. It had an electronic digital control board , the clock worked fine. To replace the oven new was like $700. We had a Sears repair guy come and he said to use the internet to find a replacement control board. After extensive research using the numbers on the board itself I found a company in Canada that does repairs, (there were a couple of companies offering this service, I can't remember why I picked the Canadian company) they explained that using a new replacement may just give you another board with the same weakness built in. This made sense to me so I took a chance and mailed them the board (shipping to Canada was a bit high) got it back in a couple of weeks, took 5 minutes to re-install and its working great. The repair was just under $140 plus shipping.
Apr 17, 2014 | Ovens
After pre heating oven, unit tripped the circut breaker. After re-setting breaker, all but the oven bake cycle worked. Now after about 2 hours, all seems fine. What caused the circut breaker to trip?
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor. To solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Ovens
Have whirlpool oven model # RBD305PDB14. Was told controller board was out. Old controller was part # 8302319, which I am told has been replaced by part # W10244191. I bought W10244191, but find that...
ggg1234~ I don't have a solution unfortunately, but I'm having the same problem. I had someone come out to look at it and they said that part #W10244191 was a mistake b/c of the larger slot and Whirlpool hasn't started production on correcting this problem... nice,eh?! I think this is a Whirlppol problem and they need to do something about it, and quick!
Nov 19, 2010 | Ovens
Kenmore electric wall oven will not increase in heat after the setting has been selected. The display is held at a constant 100 degrees; which normally increases as the oven heats up. There is a clicking...
the most common is the control board.you may have to contact the manufacturer for a new board,my supplier does not have a replacement board listed
Jan 23, 2010 | Ovens
E2 F6 ??? What the? Oven came with house, no manual.
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 12, 2009 | Whirlpool RBD305PD Electric Double Oven
F1 fault code Frigidaire electric range
Hi, you stated that you cooked a meal that produced some humidity inside the oven. this is the cause of the F-1 code. the humid conditions that were present at the time, caused the EOC(electronic Oven Control) to short. you will need to replace this control board at this time. it has failed.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
No lights on panel can't read temp. or time how to replace lig
Sounds like another control board failure, common on this type oven. It appears that a capacitor (#C3 on board) overheats and goes bad. Replacement of cap is a simple soldering job but the caps can be hard to find, try electronics parts houses and explain you need a high temp replacement. Should cost you about a buck. See post by BrianGem back in may of 2008, who turned me on to the target cap. Its a 35Volt 86mF. DISCONNECT OR TURN OFF POWER PRIOR TO ANY REPAIRS.
Mar 07, 2009 | Jenn-Air WW27430P Stainless Steel Electric...
Oven does not start
This is an update from James758. When I pressed the temp sensor probe and wiggled it a bit, sometimes the oven would work, but then it failed permanently after a few days. Had to call a repairman who charged $325 to replace the entire electronic panel and the separate sensor, although the failed part was only a relay on the board according to him. He also found a pinched wire when he pulled the oven out (one new electronic board relay failed when he first replaced it). Don't know how the wire to the sensor got pinched since the oven worked for 8 years without us moving that hidden wire. By the way, buying the sensor at a parts store in town was $18 versus his cost to us of $49. I'm sure the electronic board would also be much cheaper online. My wife watched the repairman replace the parts; you can save a lot of money doing it yourself.
Nov 14, 2008 | GE Profile JTP18 Electric Single Oven
Jenn air oven display
the digital display on my jenn-air oven, model jjw9527c...has gone completely out. i am very efficient in wiring and electronics and would have no problem fixing it myself, just not sure which parts i need to order. Please return this with a solution, holiday season is very close.....thank u
Feb 09, 2008 | Jenn-Air JJW9527C Expressions Collection...
Ovens Logo
55 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
