I have three 100w 8ohm SKM 200s ONKYO speakers, two SKF 100w 8ohm 200f ONKYO speakers, and a SKW 200 ONLYO subwoofer. I want to know what amplifire suits me best.
I want to know what kind of amplifier I need for my set including: Three 100w 8ohm SKM 200s ONKYO speakers Two SKF 100w 8ohm 200f ONKYO speakers SKW 200 ONLYO subwoofer
  • 11800 Answers
SOURCE: My Onkyo SKW-520 subwoofer has
This is caused by the aging of a component from the amplifier - as they age the capacity gets lower = the resistance to the lower frequencies increases = the sound gets weaker.
To fix that you must open the subwoofer and check all the electrolytic capacitors from the signal path - all the way from the input RCA jack to the output of the integrated amplifier.
Posted on Oct 03, 2010
SOURCE: onkyo 875 suboofer problem
decided to get a technician over.
Posted on Apr 23, 2008
jomabug76
  • 1148 Answers
SOURCE: ONKYO Speaker system model SKM-240S
YEH SHOULD BE BLE 2
Posted on Oct 05, 2008
SOURCE: Onkyo HTR500 no sound from the surround speakers or subwoofer
I have the Samsung 61" DLP HDTV and the Samsung Blu-ray BD-P1500 and the Onkyo HT-R500 receiver. I have the TV connected via HDMI (HDMI 3/DVI) to my HD DVR from my cable company and the Blu-ray player connected to the TV as well (HDMI 1). I have a fiber optic connection from the receiver to the Blu-ray (since the P1500) does not have digial coax ouput for connection to the receiver. With Speaker A button pushed, and all my speakers are wired, the only sound I get from my 5.1 channel system is static from the front right and front left speakers so I know there is a connection. When I try to listen to the DVD Player (which was working without the receiver as a Stereo only-mode), I had sound but now that the 5.1 channel system is connected, there's no sound while watching a DVD nor can I hear anything with my CD Player which is connected with standard red/white RCA cables.
Any advice on how to get the sound or what "settings" I am missing?
Thanks
cigar_brett (at) yahoo (dot) com
Posted on Oct 21, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
Onkyo sub will not power up?
does the green light power up on the back? If not the power supply is bad
Aug 25, 2011 | Onkyo SKW-200 Subwoofer
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
Subwoofer stops working at times and will not work.have had it about 4 or 5 days just started doing it today
many pple have the same problem.... that subwoofer stops working sometimes when playing music or something else... I also faced the same problem .... I did the following things..
open your subwoofer. checked all connections for any loose contacts... and then check the wire of the main speaker.....
IF YOU FIND DIFFICULTIES IN OPENING OR IF YOU DONT KNOW MORE ABOUT THE INTERNAL PARTS OF SUBWOOFERS.. THEN DONT TRY TO OPEN IT.. YOU MAY CAUSE DAMAGE TO IT...IN THIS CASE :
GIVE YOUR SUBWOOFERS TO THE SERVICE CENTRE FOR REPAIRING...
Dec 15, 2010 | Onkyo SKW-200 Subwoofer
My onkyo skw 200 sub woofer is blowing fuses as soon as i plug it in
The amp output stage or the power supply is shorted. Service shop type repair.
Mar 03, 2010 | Onkyo Audio Players & Recorders
Onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
My onkyo subwoofer does not turn on the green ligth is not on, what could it be? is a swk-200
My Onkyo S/W did the same thing untill I unplugged it from the surge protector that all the other A/V devices are plugged into. I plugged the sub into it's very own wall recepticle with it's very own new surge protector. Maybe cleaner power is the answer.
No sound coming out of my Onkyo SKW-200 subwoofer
A subwoofer is just really a mono amp for the signal. As with all amps if you touch the audio section/parts with a small screwdriver, you should hear a buzz from the speaker. (Follow the audio wires to be certain you are on the audio section). This can be used for testing the amp section. If you get no buzz or noise (anywhere) at all then it's power supply could be playing up. If you have a multimeter you can test it looking to see if it is getting power. Allways suspect any part that is on a heatsink. Before removing any suspect you can put the part numbers into Google to see if you can get them and it will give you a clue to cost.
PS don't short any parts when you touch with a screwdriver, and don't put it on the power parts.
Feb 02, 2010 | Onkyo SKW-200 Subwoofer
IC with number missing
use a bigger gage power wire
Aug 08, 2009 | Car Audio & Video
Onkyo sks-ht540 subwoofer
Sounds like power problem of some sort ,have you read the instructions properly.some of these will have on/off switches in the wierdest of places
May 25, 2007 | Onkyo SKW-200 Subwoofer
234 people viewed this question
 Grubhead
Grubhead
