Shinco LCD tv hdmi DTV 3218 audio ok & video not visuval
5 Suggested Answers
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
I found the fix. Had the same problem.
I right clicked on the sound speaker icon in the bottom right of Windows 7.
Chose Playback Devices.
Once this window opens, then make sure you are on the Playback tab.
Scroll down until you see the HDMI Device. (Mine was hidden at the bottom of the list.)
Then choose "set as default".
The sound will begin playing on the TV with only the HDMI connected......no need for an extra audio cable.
Posted on Jul 14, 2013
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Hi i'v bought a LG LD 310 lcd tv and i want to
I tried this.. and it works perfect for the video.. but there is no audio.
Is there any specific setting to be made in TV or my laptop?
I have Dell laptop with Win7, because I dont see any option to enable audio..
Aug 01, 2011 | LG Televison & Video
No sound. just got connected to direct tv and now no sound. cannot see behind tv to know which red and whit jacks are audio in.
I would strongly suggest buying a HDMI cable and run it from your DTV console to your TVs HDMI input and this cable takes care on audio and video. This is relatively easy but get someone to give you a hand if you are limited in what you can do. You then must go into the TVs menu and make some simple choices.
God Bless
Bill
Jul 04, 2011 | Akai LCT4216 42 in. LCD Television
Yamaha rx-v365 plugged in the hdmi from cable box
You have to configure your DTV input to use optical audio instead of analog dtv audio (red/white plugs). Input assignment should be described in the manual. Come back to me if you have still problems with it.
Dec 26, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
I plugged in my cable HDMI into my RX - V365 Yamaha reciever. and HDMI into my TV. I get video, but cannot get my attached (to reciever) speakers to play. Help
RX-V365 doesn't support HDMI audio. You need to connect the cable box also via spdif cable for audio to work. Look at the box if it uses optical spdif or coax spdif. If optical, you see that optical input on receiver is named DTV/CATV, so use also DTV HDMI for video. Coax spdif is named DVD, so in this case you will need to use DVD HDMI input.
Also you need to configure the inputs accordingly.
Nov 14, 2009 | Yamaha Rx-v365 A/V Home Theater Receiver
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Oct 31, 2009 | Yamaha RX-V363 Receiver
My menu says dtv Currently unavailable. How do I use the HD feature on my Olevia LT32HV
Do you have a High Definition cable/satellite reciever or a Blu-Ray player? Does your tv have a HDMI input or component or DVi or all of those? Most newer HD components use the HDMI connection. The HDMI connection is a single cable that has both video and digital audio together. The component connection is a connector with three rca jacks that are red, green, and blue. Audio is connected seperately with this connection via red and green rca audio jacks or a digital audio connector. The last is a DVi connector that is found on computers. Some older HD tvs and components use this connection. There are adapters available to turn a DVi connection into a HDMI connection. So if your TV does not have a HDMI connection but your HD reciever does you can use and adapter but you will not have any audio this way without using a seperate connector for the audio.
Sep 16, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
I have my xbox 360 connected via hdmi to my yamaha rx-v363 receiver, and the receiver connected to my sony bravia lcd tv via hdmi as well. The xbox picture comes through to the tv fine, but the sound will...
Connect Xbox via HDMI to DTV/IN, Connect HDMI from out to Sony Bavia's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
OH: choose the DTV input then stereo and then dolby 5.1 etc .. cheers
Sep 04, 2009 | Yamaha RX-V363 Receiver
Hdmi connections
Hi, If you are trying to use HDMI video, and want to give autdio input separately, that can be done in many ways. In fact I am giving HDMI video from my HTPC at DTV inoput and audio over SPDIF (optical). In the menu there is an inout select option. You need to go into DTV, then select which audio to use. You can then choose whoch input port for audio is being used with DTV.
I have issues with HDMI input as well, but those have to do with refresh rate of 60 Hz and 1080i.
Dec 29, 2007 | Yamaha RX-V2700 Receiver
Televison & Video Logo
Top Televison & Video Experts
