Question about Ryobi Ry09050 26cc 200mph Gas Handheld Leaf Blower/vac
Ryobi ry09050 will not start, doesnt have a spark
2 Suggested Answers
  • 58 Answers
SOURCE: This site advertised a manual for a Ryobi Ry09050
I had the same problem with one of mine. Solution? I called Ryobi Customer Service at 1-800-525-2579 and got the manual.
Posted on Nov 28, 2010
My blower will not start
Almost positive the fuel lines are clogged if the gas has ethanol in it. Happened to my Ryobi string trimmer 2 years ago. Replaced the fuel lines from the tank to the carb.
Sep 08, 2014 | Ryobi Garden
Not geting fire to the plug
Hi Dennis
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Bud
Oct 10, 2013 | Ryobi Ry09050 26cc 200mph Gas Handheld...
No spark
Try changing the spark plug. These two cycle engines are really rough on plugs.
Sep 27, 2017 | Ryobi Ry09050 26cc 200mph Gas Handheld...
I have a new ryobi ry09050 blower/vacuum and it is almost impossible to start. I Cranked for 30 minutes and no luck, not even a hint orf startion'g I would like a manual for this machine. It is either...
take the carby in for overhaul and new diaphragm kit fitted
the main diaphragm is hard and not sealing on the holes so it is not pumping fuel
40: 1 or 50: 1 is alright and the gap is .020-.025"
why I say that is that stihl use an oil that mixes as 50:1 but it is suitable for the full range of ratios in the stihl range of engines
makes no difference what brand of engine , the ratio is to ensure enough oil to lubricate the bearings and cylinders
Jun 08, 2017 | Ryobi Garden
This site advertised a manual for a Ryobi Ry09050 Blower/Vacuum. Can't find. Would some one post a link please.
Nov 28, 2010 | Ryobi Garden
I have the Ryobi RY09050 gas blower/ vacuum brand new bought from Home Depot. I try to start it cold as said in the manual. I pull, and pull, and pull, and pull on a flat surface and it does not even...
i would check for spark, if it has spark, then I would pour a little mixed gas down the into the cylinder, reinsert spark plug and then try starting it again, if it starts then dies. Then it is not getting gas for some reason. Hope this helped Tim
Nov 14, 2010 | Garden
I bought a surplus ryobi 20cc grasscutter.it starts for a while and sundenly stops.carbs good,new sparkplugs.and found out that current from the ignition coil doesnt flow how can i fix this problem,,
U have diagnosed this to the ign coil. To make sure its the coil unplug the kill wire and see if spark is present. If not bad coil good luck!
Oct 21, 2009 | Ryobi Garden
Ryobi Ry09050 26cc 200mph Gas Handheld Leaf Blower/vac Logo
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
