Question about Xerox WorkCentre 3220 All-In-One Laser Printer
Document Jam Xerox Work Centre 3220
We had a document jam with several sheets of paper in the automatic feeder. We have removed all sheets and there were no pieces since the sheets were not torn. Now we keep getting document jam, we have taken the roller off and reseated it. I can manually feed a sheet of paper through the ADF area and it goes through. We have checked and there are no papers stuck in the paper tray area or in the area in the back of the printer. I have reset back to factory settings. What else can I try to clear the document jam message. I can take a piece of paper and put it into the manual tray feeder and print from my computer. I can't get it to scan at all even by putting it on the glass.
3 Suggested Answers
  • 2072 Answers
SOURCE: Xerox Phaser 8400 Error code 07,010.43:99907
You manually rotated the aluminum drum? Since you did that, I would suspect you have the print head wiper blade stuck between the drum and print head. The code you are getting it caused by the print head not being able to move freely.
The jamming is probably due to a bad registration clutch. Common failure on that machine.
You can go to Xerox.com, there is under documentation and drivers a parts list for that machine. You can reference the wiper blade and get the clutch part number there.
Let me know what other information you may need. I will be glad to help you get it running again.
Posted on Jun 18, 2009
SOURCE: When trying to print I
pleas try to use a plower to clean the paper way from paper tray to toner .
Posted on Dec 05, 2010
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
My Documate 152 is saying paper jam but no paper jam
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder).
Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Mar 26, 2010 | Xerox DocuMate 152 Pass-Through Scanner
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Jam in the document feeder
get rid of that hp piece o crust. demand your money back.
Mar 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
E9 code
E9 code means there is a paper jam.
Clearing Paper Jams
Document Feeder, a warning dialog box opens after a few
moments.
1. Press the ADF cover release on the top-left of the scanner
body to open the Automatic Document Feeder cover.
To reduce the number of paper jams, smooth and straighten the
paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
Dec 04, 2008 | Xerox DocuMate 252 Path-Through Scanner
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
Aug 05, 2008 | Office Equipment & Supplies
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Xerox WorkCentre 3220 All-In-One Laser Printer Logo
79 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
