Question about Sewing Machines
Bobin tension on my singer 317 how do i set it
3 Suggested Answers
SOURCE: Singer 6215c, the bobin thread is catching on the
adjust the tiny screw
Posted on Apr 17, 2010
SOURCE: Singer Merritt 3015 Tension
the tension dial may be going out & need to be replaced at a sewing machine repair shop
Posted on May 21, 2012
Top thrd snags on bobin aftr 14or15 stitches. Chnged thread, needle and bbin. Tug'd on thrd while threading, not tension.Just srvced but set a month before I sewed on it.Singer 600 Touch n Sew Slant.
Try a brand new needle. If it is still malfunctioning, most like it is out of time. You can search the internet for sewing machine timing or take it back for service.
Dec 06, 2016 | Singer Sewing Machines
My singer machine 2263 is leaving long loops under the cloth.I have tried every thing but nothing works, can you help?
Be sure to use a brand new needle.
Remove the upper thread from the machine. ALWAYS RAISE the presser foot--this releases the tension disk so the thread will seat properly. Rethread the upper thread, making sure the path is correct.
Set the upper tension to the midway point (this is the standard starting point, but may need to be tweaked for your particular machine).
Now, retest your machine.
Oct 10, 2016 | Singer Sewing Machines
How do I adjust the bobin tension?
here is a link for a free manual that should have the information in it that tell about bobbin tension
http://www.singerco.com/uploads/download/f3eff19dd0b1966512ad6a6bd24e3d8a74926fca.pdf
Sep 10, 2013 | Singer 7422
How to adjust stich tension on singer finesse 827
tension should usally be set between 3 and 4 on the top tension and never mess with the bobin tension
Aug 14, 2010 | Sewing Machines
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
How do I tighten the tension on the bobin thread I am quitiing with invisible thread on the top and dark blue on the bottom, the bobin thread shows. I don't want that
you can either increase the bottom tension or reduce the top tension .. you will notice a little screw on the bobin case ... that screw adjusts the force on a small flat spring which provides the bottom tension (the thread goes under the spring when properly threaded) .. .. tighten that screw a little to increase bottom tension .. you can pull thread thru the bobin case to get a feel for how much tension you have ... you dont have to turn the screw very far to make a significant difference .. try just 1/4 of a turn at a time .. remember where it was originally set so you can put it back when you are finished with your present project .. the greater the bottom tension the less bobin thread will show at the top ... if you get the tension too high then you might see some puckering as you sew ..
Jan 03, 2010 | Sewing Machines
I have a singer merritt 9612 but it doesn´t get the threat of the bobin
The problem is solved, it was the tension in the sewing machine. Now I know it must be always en 4. Thank you and God bless you.
Jul 22, 2009 | Singer 20U73
Broder avec la singer tradition 2250
AUGMENTEZ(LEVEZ) TOUJOURS le pied de presse quand le filetage le fil sup?rieur.
Apr 25, 2017 | Singer 2250 Tradition
Model 8280. The thread on the bottom keeps bunching up. It is a horrible mass of thread. Then, it stops moving. Can you help me?
I had the same problem and I tried everything including removing the bobin case, cleaning out lint, changing the needle, adjusting the tension but it did not work. Then I finally tried reloading the bobin thread, making sure to load the bobin according the manual directions....and the problem was solved...no more tangles... just a nice even stitch...yeah!
Jan 04, 2009 | Singer 8280 Mechanical Sewing Machine
Thread bunches from the bottom while sewing.
Hello, sewing is a part of my income and I've encountered this problem before and managed to fix it on my own, by trying out these different things. I re-threaded the machine and checked to make sure that the tension is not too loose. Check the bobin and the sack the bobin fits into, sometimes it comes loose too, click it back into place and re-do the bobin. adjust the tightness of the stiitches, I usually put it on 2 .5 - 3. Hope this helps. Good luck to all. Nefishakh@hotmail.com
Nov 16, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
