Question about HP Pavilion dv9000z Notebook
Shutting down ,HIbernating
How can i shut down hibernating if i can't get online,puter opens to page that says start windows then it goes to windows logo and shuts down then comes bk to same page sorry about error windows will start in so many seconds,then goes thru same cycle again I have a HP Pavilion dv9000
  • 41 Answers
As soon as you turn on your PC, tap the F11 key on the keyboard while the "Press F11 for recovery" message is displayed; continue tapping until you get the "Windows is loading files..." message.
When Recovery Manager has loaded click advanced options
Choose system recovery
If you wish to try and backup any data then choose backup your files first and follow the on screen instructions
To run the recovery without backing up your data choose to recover without back up
The recovery will launch and restore your system back to it's factory default state
Posted on Jan 19, 2009
    Genius:
  • HP Master
  • 1,102 Answers
Open control panel then display then click screen saver
then power at bottom of page In there you will find Hibernate and other settings that you can change you can disable able hibernate standby and sleep
Then click apply
restart let me know if this was helpful
My m14x keeps shutting down when i usethe keyboard
Open Control Panel, Power Options, Set to High Performance, Open Advanced Power settings, Set Sleep and Hibernate to Never, adjust other advanced settings to your preference. If this fails to fix, Return it at once while your warranty is valid. After Dell bought Alienware they sort of went south.
Jan 23, 2013 | Dell Alienware M14x (dkfobs15) PC Notebook
Tip
How to enable hibernation in Windows XP
Hibernation is a low-power mode that laptops use when they are idle in order to save power. A hibernating computer can come back up to ready a lot quicker than a computer that is completely shut down, but it only uses marginally more power while it is hibernating.
To enable hibernation, open the Power Options applet in the Control Panel. Click on the Hibernate tab (the farthest one on the right) and check the box next to "Enable hibernation." Beneath this box you will see the amount of disk space required to use hibernation. (This amount is typically about the same as the amount of RAM you have installed, because when the computer hibernates, everything in RAM is written to the hard drive.) If you do not have enough free hard drive space, you won't be able to use hibernation; delete some old programs or files that you no longer need in order to free up some more room.
Once you have enabled hibernation and clicked Apply, you can tell Windows when to use hibernation. Go to the Advanced tab (still in Power Options). Under the "Power buttons" heading, there are settings for different actions, such as closing your laptop's lid or pressing the power button. If you want your computer to hibernate when any of these actions are performed, just choose Hibernate from the drop down list. You can also make your computer hibernate manually by choosing Hibernate from the shut down options (Start menu > Shut Down).
Your changes will take effect as soon as you click Apply or OK.
on May 28, 2010 | Computers & Internet
Tip
HIBERNATION
THE OPERATING SYSTEMS WHICH THE MICROSOFT HAVE PRESENTED TO US HAVE MANY ADVANTAGES AND NOW I AM SHARING ONE WITH YOU FRIENDS.
WHEN WE ARE DOING A TASK,IF WE WANT TO GO FOR ANOTHER WORK LEAVING THE COMPUTER ALONE,WE USUALLY SAVE THE WORK AND SHUTDOWN THE SYSTEM AND GO FOR THE NEW WORK.BY A SIMPLE TECHNIQUE THIS CAN BE AVOIDED AND WE CAN REENTER INTO THE WORK WHICH WE WHERE DOING BEFORE SHUTDOWN.THIS FEATURE IS CALLED HIBERNATION.THE STEPS TO DO THIS IS THE FOLLOWING.
1.Click Start
2.Select Settings-Control panel- Power options-Hibernate- Enable hibernation.
3.The system can be left to hibernate by selecting the turnoff option,then point the mouse to the stand by option and by pressing down the shift key,select it,then you can see the option as hibernate and select it.Then you can see instead of shutting down windows,it gives the message as hibernating.Then it is ready,then you can return to the work by again pressing the main power switch of the CPU.Try it and look how amazing it is.
WARNING:First go for a trial with open windows(2 or 3......) and then try in actual practice.Does not cause any failure to the system 100% safe operation.Thank you
on Dec 28, 2008 | Microsoft Windows XP Home Edition
Hp pavilion ze1115 stuck on hibernating..
Open Control Panel, Power, power settings, change power settings to high performance, Disable Hibernation, sleep. When your laptop is not in use shut it down and unplug. It will last longer and a boot everyday will reset the laptop.
Dec 17, 2012 | HP Pavilion ze1115 Notebook
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
Jun 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Overusage of computer HELP!!
yes hibernate is as good asd a shut down
u need to remember it is better to shut your comp down always when you are not using it
Jun 16, 2009 | Dell Inspiron 1521 Notebook
I have a HP Pavillion dv6000 laptop, the start button doesn't start windows, but only QuickPlay begins and opens up. From that there's a windows icon for which I click on to start windows. But the screen...
Start windows in safe mode, if you have antivirus installes run it from safe mode, if it does into stand by in safe mode, you may have other issues but it sounds like a virus to me so far.
Dec 11, 2008 | HP Computers & Internet
Hibernating
What do you mean shutting down the hibernating mode? Stop it happening when the battery goes low, or shutting down into hibernate mode?
Aug 20, 2008 | Compaq Presario Notebook
HP Pavilion dv9000z Notebook Logo
148 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
