Question about Xerox Office Equipment & Supplies
Hi, does anyone know's what's the xerox 4110 copier/printer error code 010-315? it's not on manuals guide error code list. thanks
  • 18 Answers
SOURCE: Error code
ID sensor dirty or  faulty ID sensor, Old drum, worn developer. When cleaning sensor be careful if you use a vacumcleaner can blow sensor with static. Ideally call service engineer.
Posted on Oct 15, 2007
tech435
  • 284 Answers
SOURCE: DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
Posted on Sep 30, 2008
checkitright
  • 1362 Answers
SOURCE: U4 error code - Xerox 5328 copier
U4-2 Low fuser temp problem U4-3 High fuser temp problem U4-4 High fuser temp problem U4-6 High fuser temp problem
replace thermistor in fuser unit
Posted on Oct 06, 2008
  • 3 Answers
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
SOURCE: Xerox Doc12 10-386 error code
10-386 Error
Posted on Dec 01, 2008
Xerox C2424 error code 19,003.48 and 07,010.43
for error code 07,010.43
Access the power switch by opening the Interface Cover on the right side of the machine.
click on this:
for maintainance
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_maintenance.pdf
for troubleshooting:
http://www.office.xerox.com/userdoc/C2424/C2424_Web/pdfs/en/ug_trouble.pdf
Jan 30, 2008 | Office Equipment & Supplies
Error code list
Hi, you can find the error code list for the DocuColor 3535 in the Troubleshooting section of the manual. If you don't have a user manual, you can download a PDF version from Xerox here:
http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Mar 08, 2010 | Xerox DocuColor 3535 Copier
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
I'm running a xerox 4110 at the kinkos i work at with the error code 012-322. Tech won't be out for another day and i need to start this job... Any idea if this is a quick fix??? Thanks!!
Thst is a hole punch home position sensor not detecting the 2 or 3 hole punch.
Try reseating the hole punch assembly then power the machine off and on.
Aug 10, 2008 | Xerox Office Equipment & Supplies
Error code 9 - 358
Hi,that means ,cleaning auger is stopped.Probably toner waste container is full.Try to remove and replace waste toner container(or vacuum toner from container).
BR
Feb 20, 2008 | Xerox DocuColor 12 Printer
Error Code for Xerox 5313
Try this site under Tech Info.
Also look inder 5312 and 5314, They are the same product.
Here is the link.
https://www.partsdrop.com/store/
Jan 16, 2008 | Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON...
Error code for 8550
Call Xerox, they have a problem with this code and the ink loader needs to be updated.
It has to do with the yellow sicks loading properly
Oct 31, 2007 | Xerox Phaser 8550DX Laser Printer
32 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
