Question about HP ScanJet 2400 Flatbed Scanner
I have a scanjet3500C. There is no way to activate the lamp (none of the buttons work on the front panel) and the software director shows me the last thing I scanned successfully. I have a theory it's the power supply. What do you think?
    President:
  • 2,692 Answers
Sounds resonable. You may confirm with a voltmeter. Every lead out shuld have some voltage  value. Usually when power supplies die they have no voltage on one or more secondary leads (Not the 110V going in.)
Posted on Feb 26, 2009
Turn signals not working
all else on car works perfectly (other shoe drops??????)
waring 1: no scan tool, you will fail (99%)
is battery fully charged to 12.6vdc rested or at 10v?
all 4 corners dead?
not working means dead?, flashes too fast/slow or dim? or they stick on? (5 modes to fail not counting L/R and haz)
do the hazards work? (prime evidence and not stated)
most cars before 2007 have fuse marked TURN.
but not this car... its not at all like older cars....
did you scan it first after the fuse tests? any PCM scan tool.?
2009 WK jeep
the FSM chapter 8L shows the huge list of errors the lamps can fail. DTC errors.
in fact 8 blinker codes, ! DTC errors,
there is no fuse, just for turns, (trailer lamps fuse 19)
read this excerpt from the FSM book.
The turn signal system operates on battery current received on a fused ignition switch output (run) circuit so that the
turn signals will only operate with the ignition switch in the On position. The hazard warning system operates on
non-switched battery current received on a fused B(+) circuit so that the hazard warning remains operational regardless
of the ignition switch position. When the turn signal system is activated, the circuitry of the left multi-function
switch and the FCM will cause the selected (right or left) turn signal indicator, front park/turn signal lamp, front side
marker lamp and rear tail/stop/turn signal lamp to flash on and off. When the hazard warning system is activated,
the circuitry of the hazard warning switch and the FCM will cause both the right side and the left side turn signal
indicators, front park/turn signal lamps, front side marker lamps and rear tail/stop/turn signal lamps to flash on and
off. The Front Control Module (FCM) can also activate the hazard warning system lamps.
end quote)
the module front control MFC, runs this
and it uses fuse 18 , if 18 blows the module goes off line and vast things fail and huge numbers OF DTCs store.
and fuse 27 MFC
MFC needs these fuses good.
keep in mind nobody has MFC internal schematics...so........
this module drives left and right side front and rear.
electronic drivers, not fuses.
the MFC is here.
the fuses are 12,13,18, 20,27 that power MFC.
25812039-lb3yimx2pwhstnjl4tgwffiq-2-0.jpg ground this end.
Aug 07, 2015 | 2009 Jeep Grand Cherokee
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
Apr 06, 2014 | Zanussi ZBF360 Electric Single Oven
Botton sensor is not working but im using remote oky
If none of the actual buttons on front or side do not work set may have a lock feature locking them out.
If only a single button is not working it will be a bad switch that the button activates--let me know if you have questions.
May 03, 2012 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Wat buttons do i push on the projector to get the menu on screen? it can turn on but none of the buttons i push will do anything. it's a x2 infocuse projector. wat can i do to fix that?
if none of the buttons work, the plug for the button panel board may be loose. remove the rear panel and secure the plug. otherwise, use the remote to get into the menu and factory reset the settings.
Nov 16, 2009 | InFocus SP-LAMP-018 Projector Lamp for X2,...
Sony KF-42WE610 Replacing the Lamp
There was another fastener which was troublesome, but with some carefull work I was able to pop it out with a long screwdriver
Jan 10, 2009 | Sony LAMP BLOCK XL2100U Projector Lamp
Sony KP-43t75 - Front panel buttons and IR sensor stopped working
TRY UNPLUGGING THE SET FROM THE WALL FOR 2 MINUTES THIS WILL ACTIVATE THE AUTO RESET WHEN YOU PLUG THE SET BACK IN.
Dec 28, 2008 | Sony KP-57WS500 57" Rear Projection...
HP Director missing from desktop
It may happen if you have version 7.0 of Internet Explorer.
Install the below patch on your system it will make the HP Director to work.
http://h30318.www3.hp.com/pub/softlib/software8/COL17377/oj-46104-1/CIT207355-HPCOM-PATCH-v8.exe
I hope it will work.
Sep 10, 2008 | HP Scanjet 5590 Flatbed Scanner
HP Director won't open. I am on XP and IE7
HP Director has a flaw and is not compatible with IE7
I have a psc 1100 and I had to update my software from HP
CHECK THIS OUT
Go to HP, this link, type in your printer model #.
It still may fail to show...if it does not show HP recommends this
work around.
Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Apr 30, 2008 | Computers & Internet
Hp 2700 series all in one printer scanning issues
Hi .
Let me first explain that the scanning softwareis seperately loaded into the computer which is called as Digital Imaging. Try the step below:
1. try scanning from scanners and cameras - 2 errors might pop up if it does not scan - an error occurred communiating with the scanning device / no HP device detected.
2. start - programs - locate for a software loaded called HP Solution Centre / HP Director.Open the software if loaed and try to scan from there. If its not loaded then insert th installation cd and click on Install more software - full.
3. In HP solution Centre / Director click setting - scan settings - scan to ..... setup - see that both the columns of front panel and available destination list should be having some icons into it (you can add and delete from any column as desired - but none should be empty)
Click the link below to ssist you with relevant troubleshooting -
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=40990&lc=en&cc=us&dlc=en&product=420428&lang=en
If none of the above work then try uninstalling and re-installing the printer software all over again
Apr 13, 2008 | HP Photosmart 2710 All-In-One InkJet...
HP ScanJet 2400 Flatbed Scanner Logo
Ben Johnson
