Question about Siemens Washing Machines
Siemens serie iq 1435 display is normal but it won't start
I selected a wash then pushed the on button. It made its normal 3 beeps but then nothing happens. The machine won't start and there is no water being taken into the machine to start the wash. What could I try please?
  • 1462 Answers
SOURCE: Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Posted on Apr 01, 2007
SOURCE: Washing Machine stopped through cycle and now will not turn on
Unplug!!! NOW! I drained the water using a common garden hose, fill the hose with water and have some device turning it off like a trigger nozzle on the low end. Detach from the supply and put the supply end in the center of the tub under the softener dispenser. take the trigger nozzle off and watch the water drain without cups and buckets. Then wring out the clothes and put them aside, use the hose trick again for remaining water. Now get under the washer and detach and reattach the brown and white lead input to the rinse cycle motor. She is made in France so be gentle. Plug the machine in and set the machine down and turn it on. Push the >> button until you reach the spin cycle if it starts you have fixed it!! Put the clothes back in open a bottle of wine and try again.
Posted on Nov 05, 2007
ngfam1
  • 639 Answers
SOURCE: washing machine wont start on any cylcle,
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
  • 22 Answers
SOURCE: Fisher&Paukel washer
might have something stuck in drainage area. see my post on "eco smart won't drain, smells hot" on how to remove motor on bottom of washer.
might also try another website, www.ths.gardenweb.com/forum/laundry to see if anyone on there has an answer.
Posted on Oct 21, 2008
SOURCE: siemens serie iq 1430 start problems\r\nThe
siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Posted on Sep 28, 2010
Siemens washing machine display F21 flashing. Fault is not resetting after power off.vario perfect iq 300.
Try this, unplug it and press and hold down the power button for 10 seconds and then plug it back in and see if the error code has cleared.
Aug 28, 2016 | Siemens Washing Machines
The washing machine turn on but don't start
It could be a poor connection at your motor. Check the white plug which plugs into your motor. Take off the cap, you'll find one of the wires is burnt. Cut the wire back to behind the fault and refit.
Dec 08, 2013 | Washing Machines
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
The lady I work for has a Siemans washing machine, Sevie? IQ 1633 and does not know how to deactivate the child lock, also ther are a few silver buttond down the side of the main screen, she has no idea...
See your manual to reset the child lock. If you see the child lock button, press and hold it for 3-5 seconds and it should beep to reset.
If that doesn't work then unplug the unit for 30 seconds and try it again.
Jun 07, 2011 | Siemens WIQ1633 Front Load Washer
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
Feb 08, 2011 | 7752V Replacement Transmitter Supercode...
I HAVE A SIEMENS SERIE IQ 1433 AND I CANT DEACTIVATE THE CHILD LOCK AFTER WASHING MY CLOTHES
Try this procedure to deactivate child lock on your washing machine:--- On Siemens washing machine to deactivate child lock set program to Easy-Care and hold option down arrow for 5 seconds. ---------------- set mode to rinse & then hold option down arrow for 5 seconds (toggles on/off). ---------------- -Set the mode to cottons, (dial clockwise once)
-Press and hold the option down touch button for 5 seconds or until you see the magic message 'Child lock released'.
----------- Check out.This will help.Thanks. Helpmech.
Jan 19, 2011 | Siemens WIQ1433 Front Load Washer
Siemens serie iq 1430 start problems\r\nThe display just flashes and goes dark Machine will not start
Sep 18, 2010 | Siemens WFXD8400UC Front Load Washer
Dryer does not start after selecting a program
How old is the unit?
This was my experience...
http://www.fixya.com/ThreadAsker.aspx?thid=1179929#
Feb 09, 2010 | Siemens Dryers
Kenmore Dishwasher displays the number "98"
I have a very similar problem. When I push a wash selection, every light on the panel shows up...and when I push Start, nothing happens. When I push cancel, it trys to drain, even tho no water is in there any more. Have you ever had an answer to your problem?
Feb 06, 2008 | Kenmore 16872 Built-in Dishwasher
Washing Machines Logo
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
