Question about Xerox DocuMate 252 Path-Through Scanner
DM 250 internal hardware fault - Xerox DocuMate 252 Path-Through Scanner
3 Suggested Answers
Toxic Hazard
  • 4 Answers
SOURCE: It's not working
I have the same problem - I tried pluging it directly wall socket - still the same error - I did notice that the plug that connects the from the front load scanner to the flat bed was not really connecting all the way.. it looked like it was but i turned off the scanner and went ahead and made sure that both screws were in all the way (its a little tuff) and then turned back on the scanner - the error went away and it does appear the the connection was not being made completly - I was able to scan several documents. I see that some of you have this as a re-occuring issue. I just got this scanner for one of our locations. Hopfully it does not reoccure.
Posted on Aug 20, 2009
Did you guys flip the lock switch? (On the bottom of the unit)
Posted on Aug 26, 2009
How to install dm
Please clarify what you mean by install DM so I can help you with an accurage solution.
I will watch for your reply.
Brian
Feb 19, 2011 | Seagate (HDD-CS-ST3250310NS) 250 GB SATA...
Greenlee dm-60: not working
check internal fuse , check battery , check probes to make sure there is no break in cable
Jun 16, 2010 | Greenlee Dm - 60 Digital Multimeter...
Hello, i have dream box DM 800 HD PVR
Hardware. Check the power source, the 18v is used only for the LNB.
Feb 12, 2010 | RCA DISH Network(r) 311 Satellite System
Logitec250headset mic not working at all on this pc
Hi, Please uninstall any logitech software version present on your OS - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Aug 25, 2009 | Logitech 250 Headset
Olympus DM-10,locked in a "Read Only" mode
The recorder should be formatted only by using the internal FORMAT function found in the recorder’s Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended.
Apr 10, 2009 | Olympus DM-10 Digital Voice Recorder
I m having 250 gb hdd & i wants to make that dos bootable & xp bootable the DM I M having only support 160gb hdd that is not showing above that if u have dm for that can u arrange for me
dude your motherboard does not support harddrives larger than 160GB buy an external one but if you want to use that go ahead and use it but connected in slave if your using another harddrive as master where windows is installed or in master if you want just that hraddrive
Jan 27, 2009 | Computers & Internet
It's not working
Aug 14, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Drivers for cyberdrive dm 166d dvd
Have you tried www.drivers.co,? How about restoring your system back to a previous day and time before your problem began?
Dec 29, 2007 | CyberDrive DVD-ROM DM-166D Internal DVD...
Hardware Internal Fault
This looks like a hardware fault. I hope (by now) that you have got an RMA and had it replaced.
Oct 13, 2007 | Visioneer 9450 Flatbed Scanner
Xerox DocuMate 252 Path-Through Scanner Logo
179 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
