Question about Fisher and Paykel GWL11 Top Load Washer
Slow fill on cold water/Fisher&Paykel GWL11
I have a Fisher and Paykel model GWL11 that fills very, very, slowly on the cold water setting. The water pressure is good and I have cleaned the filter screen that goes into the machine. I also replaced the deverter valve, but it still fills very slowly on the cold setting. Pleae help, thank you.
  • glib48964 Jan 28, 2009
    Thank you! That was it! The test sheet was the key to identifing the problem. Everyone that has this washer should know about the service sheet. Thanks for the info. Fisher Paykel sent the part very fast ($32.00 total with shipping) I was very impressed. I was able to do the repair with one screwdriver and it took about 30min start to finish. Thank you again. My wife thanks you as well!!!!!
  • Anonymous Mar 15, 2014
    Cold water will not fill alone....only hot comes in when I set it to cold
Assuming you have already done what you said you have done, now it is time to do some real troubleshooting.(Dont worry, if you have gone this far you'll be able to do what I'm going to tell you)
First take the lid off. To do this, open it, and lift up on one side, it should come right off. Now take the control panel cover off. There are two screws on the back side of the washer holding it on. You'll need to wiggle it a bit to get it off. Once the cover is off you should find a plastic bag with a "service" sheet in it. The service sheet explain how to put the machine into the "Test Mode". This is very easy to do and will allow you to check out all functions. One of the test, allows you to check the cold water inlet valve. Assuming your water pressure is good and you have indeed cleaned the screen filter going into the machine you will most likely find that the cold water valve is not opening all the way and will need to be replaced. If your handy with a phillips screwdriver you only have two more screws to take out and the valve assembly will come right out.
Don't think you can swap out the hot water valve with the cold water valve. Fisher Paykel, clever as they are made sure you can't do that. One is a proportional valve and the other is a digital valve. They both look identical but they are not!
If your going to do the repair yourself (you've come this far, why not see it through to conclusion), be sure when you call Fisher/Paykel to order the cold water inlet valve that you give them the serial number of your machine to be sure you get the correct part.
Good Luck!
Posted on Jan 27, 2009
Why won't fisher & paykel gwl11 fill cold water?
If the cold water only comes out at a trickle, you need to replace the valve. I have had to replace the hot and cold water valves on my washer every couple years.
Jul 06, 2014 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel washer will not stop filling with water. It is pumped out as fast as it fills. Model gwl11
If water is draining out as it is coming in, then more than likely the drain line is pushed too far down in the drain and causing a siphon effect. The end of the drain line has to be higher than the drain pump itself or this will happen.
Jun 21, 2012 | Fisher and Paykel Washing Machines
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 takes forever to fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hot water will not fill into unit. hot water is hooked up and line feels hot. ?
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer will not fill up with hot or cold water
i would say its your water inlet valve have it tested or better stil replace it..
Jul 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer will not fill with water. Machine goes on but groans and no water fills. I have unplugged it for 60 seconds but still no water
Water inlet valve problems are not uncommon with these machines.You probably have to replace the cold valve (Most common) The groaning is probably the bowl turning slowly to allow the water to dampen the clothes evenly as it fills....DO NOT try to exchange the hot and cold valves, as they are different!!!! Not a big job for a tech....Good luck....Nomess
Jun 08, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher&Paykel Smart Drive 601 Both Hot and Cold Water Fill very slowly
Hey there. I've had the same problem recently. It would fill slowly, and then after a while, it wouldn't fill at all. So I got some a new valve. it cost about $NZ30 delivered. You'll need one each for hot and cold. You can get parts from http://www.primedistributors.co.nz/. I think the part you need is 426142. you can check an image of it on the website. Good luck.
Aug 17, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
813 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
