Question about Minolta DI-2010F Copier
NO LIGHT NO MOVEMENT INSIDE.
I have a Minolta CSPRO EP 2010 copier.When I introduce a paper for a copy, it comes at the other side without printing.I have open the upside to see what is wrong and I have notice this:
WHEN THE PAPER IS CROSSING THE SYSTEM THERE IS NO LIGHT INSIDE THE MACHINE AND THE UNIT CARRING THE LAMPS IS NOT MOVING AS USUAL.
If there is no light coming from the lamp in the scanner and the carriage is not moving this is a serious problem. It could be that the main board is bad. Typically the exposure lamp is just burnt out but if the carriage is not moving something more serious is not working. Just to verify open the document feeder on top and press the start key. You should get an error code if the lamp does not work.
Posted on Jan 23, 2009
Cspro ep 2030 minolta copying rough in the morning, but okay in the afternoon, solution please
Sounds like the warm up controls are not opperating properly. Or it is in a very cold environment. The "fuser" that provides the heat required to "glue" the toner to the paper may be defective, or the connections to it's controller or the controller is defective. Temporary solution may be to leave it "on" overnight to keep it as warm as it gets in the afternoon. Will take more electricity. But eventually it will need to be repaired, or replaced with a lightly used equivelent. It may be less costly than repair.
May 07, 2015 | Minolta Office Equipment & Supplies
MMY COPY MACHINE IS CSPRO MODEL EP 3010 MINOLTA APER ERROR CODE C061
Lens Motor, under the big glass is to your right is the lens assy. there is a motor that works the mirrors on that side it is either jammed or burned out. Or worse case the board controlling it is bad. You have a Legacy Minolta Machine, get a tech out (Old School one:))
Jun 02, 2014 | Konica Minolta Office Equipment & Supplies
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
Minolta EP 2010 copier, top loading doesn't pull paper
Hello sir; try to made 2 copies one go through by adf another one just put on the glass,if one copyclean another not clean then clean up the glass, if both copy all lines then replace drum unit.
Jan 06, 2009 | Office Equipment & Supplies
COPIER PRINTING BLANK
check your corona or high voltage charger . meanwhile you can remove the developer tank rotate it manually & if it rotate fine ,remember that their is a door actuation switch that wouldnt allow the copier to rotate while the door is open . you can remove the tank & use hand to mark the toner surface then restore it & on the copier ,then remove it to know if the mark rotate . if your corona wire cut, burn or if the charger is spoiled all these can cause blank copy
Oct 10, 2008 | Office Equipment & Supplies
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
Minolta DI-2010F Copier Logo
81 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
