Question about Kitchen Ranges
How to install top baffle and back brick of stanley oisin stove properly - I am using the back flue and it is not a boiler fitted stove?
2 Suggested Answers
marbert2
  • 3 Answers
SOURCE: i have a quebb master multi fuel fire/stove
Hi Davebingj, It is quit simple to solve this problem. Inside your Quebb is a removable roof. You can lift up the roof a small bit, fold it together and pull it out of the front door. Then you have full acces to the flue pipe at the end of the stove. With the sweeping gear, which can bent easily, you can sweep the chimney very good because the sod coming out is staying inside the stove and doesn't sweep aroun the room. Hope this will help. If not give me an mail at: marbert2@eircom.net Hubert.
Posted on Mar 28, 2010
What do i need to do with my chimney to fit a log burning boiler stove
First, your chimney liner must be clean and intact. Then it will have to be lined with a flexible metal liner, that is the same diameter of the flue pipe coming off the stove, that will connect eventually to the stove. This line will provide the proper draw for the stove, as well as reduce the chance of chimney fires.In addition to the liner, there should be a weather tight chimney termination with a spark guard screen.
Hope this answered your question and thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
We do not seem to be getting as much heat from the stove this year as last year. The stove makes a loud clanking sound when it heats up and cools down. It is a regency wood stove Model R3/R9/RA3. There...
That stove has a metal baffle on top of an air tube that can warp with age. It might be changing shape as it heats up and making your sound. If this is the case it can block the path for the stove pipe and cause performance issues. The baffle plate and insulating blanket on top can be easily replaced.
Dec 07, 2010 | Stoves Heating & Cooling
I have a Dometic 2193 3 way fridge. It works
The flue baffle was the solution that worked for me as well. Below is a response I posted to a similar post.
I had a similar problem. The flue would get hot and the cooling tubes would get "warm". The refrig would get a LITTLE cool but nothing to be of any help.
I solved it though...it turns out there is a "flue baffle" (twisty little metal thing) that is supposed to hang in the inside of the baffle. It hangs from a screw found on top of the baffle and it is supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a coat hanger, then rehanging it using a new screw. That solved my problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the flue, the flue baffle, and the piece of metal holding it here:
http://www.fourwheelcampers.com/DometicRefrigerator.pdf
Look on p.9, figure 9. Item C is the flue baffle and the wire holding it. Item B is the screw that was corroded on mine, and ended up dropping the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
http://rvmobile.com/Tech/Technical.htm
Jul 14, 2010 | Dometic RM2193 Compact Refrigerator With...
Refridgerator won't cool on propane. Lights fine and stays lit. Stack gets hot. Coils are warm. Works fine on AC and DC.
Jul 12, 2010 | Dometic RM2193 Compact Refrigerator With...
No cooling on gas, works great on elect.
Jul 08, 2010 | Dometic RM2193 Compact Refrigerator With...
Rayburn nouvelle smoke exhaust from boiler burner front pipe joint-copper small od. metal washer and rope seal!
normaly this little seal and washer is enough to keep the smoke in
you must have a unclear flueway. i would remove and clean the baffles in the top of the boiler burner first that make sure i have an updraught in the main flue pipe then try again
Feb 07, 2010 | Kitchen Ranges
I need some replacement parts for my Waterford-Stanley Trinity wood stove. The Left and right top baffles. Do you know where I can buy them.
LOOK AROUND THE STOVE FOR A BRACKET WITH THE MANUFACTUOR DETAILS AND CONTACT THEM FOR INFORMATION ON PART OR GO TO A SRAP YARD AND YOU MIGHT GET LUCKY .
Nov 29, 2009 | Ovens
I have just opened up my chimney and took it back to the bare bricks and was giong to install a wood burner but decided to fit a gas stove instead. there was originally a gas fire installed so it has a...
You will need to install a flue liner ( i know its a nuisance) to allow the products of combustion to escape as quickly and as safely as possible.
If you installed a gas appliance without a liner, due to the temperature of the flue gases (lower than solid fuel) the emissions would struggle to exit via the flue terminal.
If you install the appliance following the manufacturers instructions, you cannot go wrong. The other recommendation is get a 'Gas Safe' engineer to carry out the commssioning/testing.(house insurance void if not certified)
I hope this helps.
Jul 07, 2009 | Ovens
I have a wood burning stove fitted in our modern home. The stove has a vertical flue pipe fitted from the top and up through a purpouse built chimney liner in the ceiling. the lower parts of the system...
(1) The lower "enamel" pipe is possibly Ceramic coated pipe, used for high temperature flue applications.
(2) The "stickey black tar" is creasote. Whoever installed the flue pipe did it wrong. It needs to be reversed so that the "Crimped" end of the pipe is pointing down. That way the creasote will drain back into the stove and get burned up.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Apr 01, 2017 | Heating & Cooling
Kitchen Ranges Logo
778 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
