Question about Creda Ovens
Creda solarglo double oven hotplate control knobs faulty can i replace them and how ?
Hot plate knobs not controlling tempreture
revamos
  • 16 Answers
SOURCE: Built in oven gets too hot
sounds like your thermostat is bad not sensing temp
Posted on Apr 19, 2008
SOURCE: Any chance of mailing me instruction manual.
All I wanted was a copy of the instruction book, never mind I will get one somewhere else.
Posted on Jun 12, 2009
  • 40 Answers
SOURCE: creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Posted on Apr 07, 2010
  • 1606 Answers
SOURCE: Question from electricain with long
I wonder if L1 and N are reversed, at least for this hot plate. The readings you get are consistent with a switched neutral and always-connected L1. This is not permitted in any electrical code I know.
If you get a constant 240 V at "terminal 1" referenced to "terminal 2", but no heat, and the resistance is consistent with a 1400 W heater when it's cold, I'd suspect a heater terminal or the element itself is opening up when it gets warm. If you have a means of measuring current such as a clamp-on induction ammeter, you may see an initial current up to 6 amps, then a quick drop-off to zero, random fluctuation, or cycling on and off. That would confirm my hypothesis.
Posted on Feb 07, 2011
blackmar
  • 235 Answers
SOURCE: Creda Concept Solarglo Cooker. Grill
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Posted on Feb 12, 2011
Testimonial: "Many thanks for the prompt reply. I'll follow up your recommendation!"
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
Mar 06, 2011 | Ovens
Creda Concept Solarglo Cooker. Grill not working. Elements seem ok as top oven works fine. Any ideas gratefully accepted! Thanks in anticipation.
Feb 11, 2011 | Ovens
Can you tell me how to replace a faulty switch on a Zanussi Electrolux ZCE5001X double oven. It's the switch on the control knob for the main oven.
Under the control panel you will find 3 screws which holds a heat deflector plate,remove this plate remember position.then under this are some more screws for control panel,make sure power is off.take knob off main oven switch then pull panel forwards there may be screws in side of panel check for these.On the back of the multiswitch for oven is the oven thermostat it just pulls off if you prise with a screwdriver.Then remove the 2 screws holding the switch in place get new switch and wire for wire change over wires be very careful its easy to forget where they came from.Put all back in reverse as you took apart.
Hope this helped.
May 17, 2010 | Ovens
Hotplate on ceramic cooktop not working, another won't turn down.
If 1 of the plates is not working at all, then it is going to be the plate itself, or a faulty regulator, you will have to take it apart to check the plate.
The other plate that you cannot control, needs the regulator replacing.
Mar 25, 2010 | Ovens
Jun 11, 2009 | Creda Ovens
Halogen hotplate will not turn down
You need to fit a new regulator that controls the hotplate, as the other one is faulty.
Please rate my fixya solution.
Thanks
Feb 04, 2009 | New World E70DOa Electric Double Oven
The hot plate is heating up when the selector is in off position
Hotplate heating up when regulator/selector switched off. Hi ,this is gil1714 in Scotland. Two possibilities on this one, 1) the regulator is faulty:- replace
2) if the control circuit (regulator) is wired on the neutral side the hotplate may be leaking current to
earth, thereby completing the circuit. This would only occur on a supply that was not protected by
an RCD. If so replace hotplate. Hope this is useful,
Dec 15, 2008 | Ovens
Creda colonial oven
If it is the external fan that is staying on as opposed to the oven fan then it is probably a faulty thermostat that controls the cooling fan.
Dec 04, 2008 | Zanussi ZHQ575 Electric Double Oven
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Ovens Logo
20 people viewed this question
Top Creda Ovens Experts
ashburton
Craig Butler
Craig Butler
Pcm2048
Are you a Creda Oven Expert? Answer questions, earn points and help others
