Question about Panasonic CT-32G23 32" TV
1996 32 inch Panasonic TV
When I moved my Panasonic TV Set Model CT-32G21u I failed to unscrew the co-axial connector from the back of the set. The connector on the TV set was torn off. When I tried to repair it I noticed there is an antennna module attached to the main PC board on the set. Can the antena module be replaced or can I reattached the antenna connector to the module - if so how - the wire leading from the connector to the module was broken in the moving process?
  • 2oonhed Dec 23, 2008
    I had the same problem but I fixed ok, but on continuity test the center conductor is shorted to shield.
    Is the F connector out supposed to show shorted?
  • 398 Answers
What you are calling the "antenna module" is actually the tuner. The connector that pulled out is called the F connector. The F connector can be soldered back onto the tuner but this is a very delicate procedure and is especially difficult if any of the coils in the area of the F connector have been bent, altered or moved. The tuner itself is not too expensive and is much easier to replace than trying to replace the F connector, especially if you have never done one before. If you use this set with a cable box then simply connect AV cables from the cable box to the TV set the TV to VIDEO.
Posted on Jun 27, 2007
Why does neither the co-axial cable from my DVR Cable box nor the one from my TV fit into the coaxial plug on the Magnavox ZV427MG9 DVD Recorder/VCR Combo ?
Check the coaxial cable connector type. There are two kinds--one that look like the RCA connector that you can just push in.
The other kind has a nut that you have tighten over the coaxial cable connector on the DVD recorder.
Dec 05, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Want to know if panasonic tv CT-32G31 has a fuse...shut off and i am unable to turn it on
Yes! there is a fuse on the inside of the set, unplug set, remove back cover, and follow the power supply cord to the main board, fuse should be near by.
Mar 19, 2011 | Panasonic CT-32G31 TV
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
My Lorex SV-01-RCV Wireless A/V instructions were lost in our move and I need help with the set up. Could you please help? I can not remember the correct connection.
You should have a 2-wire cable with Yellow, White and Red RCA plugs on each end.
The Yellow line is video out.
The White line is Left channel audio out.
The Red line is Right channel audio out.
Since your RCV only has two RCA jacks use the Yellow line for video and the White line for audio.
You should also have an "F-connector for co-axial cable.
If your TV set does NOT have audio and video jacks hook that to the co-ax antenna connector on the back of your TV set.
Set the RCV for either channel 3 or channel 4 and do the same with your TV set.
The RCV unit has four receive channels which must match up with the channel selected on the CAM or TX unit.
You can scan all four channels either by auto or manual.
If you only have one CAM or TX unit it probably doesn't matter which of the four you use unless you have a computer ROUTER which interferes with one of the four channels.
If so, select the 1, 2, 3, or 4 channel which has the least or no interference manually.
Bil Munsil
K1ATV HAM TV
Mesa AZ
Hams should be seen as well as heard.
Dec 30, 2009 | Home Security
How to unblock v chip in panasonic panasonic CT 27SL15 TV
Push the power button and the action button on the tv set until it shuts itself off and this will reset your tv. You cannot use the remote to reset...must use the actual tv buttons on the television set.
Jun 17, 2009 | Televison & Video
Need user guide for Panasonic 32'' TV model CT 32SF37B
I have a user guide which consists of 21 pages. FYI, you can contact Panasonic Consumer Electronics Company, Division of Matsushita, Electric Corporation of America --- One Panasonic Way, Secaucus, New Jersey 07094 or email - www.panasonic.com
Mar 26, 2009 | Panasonic CT-32SL14 32" TV
Picture shrinks horizontally every few seconds.
You are changing parts in the wrong circuit. The problem is in the vertical circuit. Look for the vertical IC and resolder the pins first. It should be an LA7837 or something similar. Also, check the 100ufd and 47ufd caps in the same circuit.
Keep us posted.
Dan
Jan 19, 2009 | Panasonic CT-20G11 TV
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
LCD TV
HD ready does not mean it has a digital tuner.
don't know what TV model you have but any TV with a coaxial connector will receive the analog broadcast. However; if your TV is not equipted with a digital tuner, you will need a set top box when analog broadcasts stop transmitting in Feb.
Aug 21, 2008 | Televison & Video
Panasonic CT-32G23 32" TV Logo
589 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
