Question about Bosch Ovens
EO 11 bosch
The oven doesent work because of the code EO 11 in the display
3 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: whirlpool model: rf385pxdz
Hi. This is a possible control board issue. First i would advise to check the wiring at the door switch mechanism, and control. Make sure the wires that link the control to the actual door latch assembly, are connected well, and are not lose. If the wires are Ok, and not corroded, simply replace the main control board.
Posted on Nov 03, 2009
SOURCE: i have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
Posted on May 14, 2012
WHEN MY WHIRLPOOL BUILT IN OVEN MODEL RBS305PRS00 IS BAKING IT SOMETIMES CUT OFF AND YOU HEAR A CLICKING NOISE AND IT WILL DISPLAY EO F3.I CAN TURN THE OVEN OFF AND IT WILL BEEP AND DISPLAY EO F3.AFTE
That's an oven sensor error. Replace the oven sensor. If you still have the error, check the wiring and/or replace the timer/clock board.
Nov 26, 2014 | Whirlpool Ovens
I have a kitchenaid convection oven with microwave F6 EO code
May 14, 2012 | GE JKP85 Electric Double Oven
Receiving an E0 error code when trying to clean a Whirlpool Accubake oven
The EO error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The EO code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Sep 18, 2011 | Ovens
Getting error code EO - F5. What's the fix???
Hello & Welcome to FixYa
Error code F5-E0 is a door latch failure and is displayed due to malfunction of door latch-switch assembly. First try to check the door latch switch, if fine then recommended repair is replacement of door latch-switch mechanism. Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Whirlpool RBS275PD Electric Single Oven
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
Whirlpool model: rf385pxdz My oven will not work, First It displays "door" then displays error code "EO F7"
Nov 03, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 25, 2009 | Ovens
LED display says door. The control pannel wont work at all.
My problem has been repaired by my husband. I do not have the self cleaning on my oven yet the control board thought my self cleaning was on and the door was open. He had to jumper a wire between a connection on pannel to confuse the code and cause the board to set a new error code that could be reset. Which we were able to set the EO code and follow procedure for power disconnect and the board rest. We now have an opperatioal oven. Thank you .
Nov 23, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool double oven
water or over spray in the panel let dry for couple days and turn back on see what happens
May 08, 2008 | Ovens
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Ovens Logo
1,335 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
