I have a Murphy LCD TV, model TV37F10DM, I've had it for a few years now and, up until recently, it worked perfectly fine. Recently however, I'm finding it more and more difficult to turn the
The tv won't respond to the remote control or a sky plus remote control, it doesn't seem to be able to turn on manually and it just does nothing.
SOURCE: new Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
Posted on Mar 29, 2007
chrispurs1
  • 372 Answers
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Posted on Jan 20, 2008
KEV TECH
  • 3 Answers
SOURCE: Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Posted on Apr 11, 2008
SOURCE: code for sky remote control for LG 42LT75 LCD TV
the remote i had was rev 6 control and i tried every number going but no luck.
i then ordered new remote control which is rev 8(you can find this when you open the battery lid)
and i typed in 0206 and it worked(bingo).
good luck
Posted on Sep 27, 2008
SOURCE: Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Posted on Oct 04, 2008
Check engine light car shaking
Failed ignition coil most likely.
Other causes...sparkplugs, HT leads.
Jun 23, 2013 | Mini Cars & Trucks
Blank screen with sound, unresponsive panel buttons
Nothing is forever or for free, suggest you donate it or recycle it.
Dec 03, 2012 | Niko OTP-3211W 32 in. LCD Television
My Emerson LC320EM1F model tv went out and didnt have power about a year ago so i let it sit until
sounds like you've spent lots of money trying to fix it already. Hope someone here can help.
Sep 18, 2012 | Emerson Lc320em1 TV
Blue screen, can't watch anything
The main board of the TV has failed. You can get parts from here and do the repair yourself with nothing more than a phillips screw driver. TV Parts Universal TV Stands DLP Chips ShopJimmy
Apr 09, 2017 | Quasar VV1309 13 in. Combo
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
Aerial Socket on LG TV ceased working
Most likely the TV has a burned out receiver board.
May 24, 2017 | LG Televison & Video
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
