Question about Dishwashers
Flashing light WHIRLPOOL ADG 8441 - Dishwashers
SOURCE: Whirlpool ADG 957. Light for
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Posted on Jan 24, 2009
SOURCE: front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Posted on Jun 11, 2009
  • 69 Answers
SOURCE: whirlpool adg 7550 starts cycle then beeps and
6 flashes indicates water intake fault ie machine is saying it has not filled with water within the required time.
-Check inlet hose not kinked or blocked.
-Next, check inlet valve is OK (check with ohm meter-should read approx 4k ohms). If no circuit thru valve, replace.
-Could also be fault with water indicator switch (much harder to access and diagnose- located underneath sump on right hand side).
-I have also had this occur because of a faulty flow meter. Flow meter measures the volume of water as machine fills. Flow meter is large plastic chamber located on left hand side of machine (accessed by removing left hand side panel). It has a sensor on the bottom with 2 blue wires. Unfortunately again, very hard to test this component without specialist equipment.
Hope this is some help- not sure how technically minded you are, but checking inlet hose for kink/obstruction is a good place to start, then advise calling service technician unless you are a confident DIYer
Posted on Aug 10, 2009
  • 901 Answers
SOURCE: Whirlpool ADG 6556 flashing code
Refer user guide for the correct meaning!
Meanwhile Check all the dispensing compartments- salt - rinse-aid, free inlet water flow and the door close.
Posted on May 21, 2010
SOURCE: adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
Posted on May 24, 2010
We have a whirlpool ADG 7800 dishwasher ,getting a beeping sound and start button flashes 12 times? Any help
Hi
Ok try this and see what happens.
Hold the start button again till it beeps
Then select the first cycle on the left which should be the rinse cycle
Then turn the dishwasher off
Then press and hold the start button and with this held in turn the dishwasher on.
Once the start light is flashing let go
Now press the start button once and close the door.
Now it will run a 12 minute test cycle. If it goes wrong it will drain the water out and beep. So open the door and count the number of flashes from the start light inbetween the pause and let me know.
Regards
Oct 11, 2014 | Whirlpool Dishwashers
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
Adg 3962 IX showing fault code f2 with flashing
May 24, 2010 | Dishwashers
May 20, 2010 | Whirlpool 24 in. ADG6552 Built-in...
Reset control panel for Whirlpool ADG 4952
whirlpool adg4952m is reading F2 and not working
Jul 04, 2009 | Dishwashers
Front light flashing
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Dishwashers Logo
105 people viewed this question
Top Dishwashers Experts
