Question about Kenmore 63942 Dryer
Kenmore 400 dryer squealing noise
I have a 1 year old Kenmore 400 dryer which makes a squealing noise that lasts about 3 seconds when I press the start button. It also occasionally makes this 3 second squealing noise at other times in the cycle (though this is very rare). The dryer works fine otherwise. Any ideas what the problem is?
    Problem Solver:
  • 20 Answers
A little lubricant on the pulleys near the belts will go along way. Its vereasy to access these parts front the back of the machine with a 1/4 hex head screwdriver.
Posted on Jan 19, 2009
Squeals while drying clothescould this be a bad belt ?
It can come from two things, belt for sure when you over load the dryer or it is getting worn an second the rubber wheels the drum sets on can squeal.
Mar 29, 2014 | Kenmore Elite HE4 Electric Dryer
Loud sound helicopter
it has outlived it's life. get a new one. they wear out after 6-10 years, and yours is about 12 years old.
Mar 08, 2018 | Dryers
My kenmore 400 electric dryer was working fine. i bought about a month ago. Up until last night. when it would turn it make a short grinding noise then a big THUNK. And i noticed the room was hotter than...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 23, 2011 | Kenmore 400 6942 Dryer
At start up on my elite oasis dryer there is a squealing sound. It only lasted for a few seconds at first. Last night I noticed the sound continued for about 30 seconds before it stopped making the...
Greg, it sounds like an issue with the belt tensioner pulley. It is one of the only parts that can and will make a little noise at first and then quiet down after it gets heated up from use.
If you post the complete model number from the dryer I can look up the breakdown and give you a part number and some step-by step instructions on how to replace it (if your up for the task).
Thanks, and good luck!
Oct 07, 2010 | Kenmore 67082 Electric Dryer
I'VE HAD MY DRYER 3 YEARS. POWER COMES ON BUT WHEN YOU PUSH START BUTTON THERE'S JUST A PAUSE AND THE ERROR CODE " F". PLEASE HELP!!
Select any one button (except POWER, START, and STOP) and follow
the steps below, using the same button (remember the button):
Press/hold
3 seconds
➔ Release for
3 seconds
➔ Press/hold
3 seconds
➔Release for
3 seconds
➔ Press/hold
3 seconds
All indicators on the console will
momentarily turn off, then turn back on with 88 displayed. After
5 seconds, the Automatic test begins.
Use the tech sheet info on page 2 as a starting point
Note to get the exact tech sheet or manual for your machine go to ServiceMatters and post your model number.
May 03, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
My kenmore dryer is making a squealing noise. It is 5 to 7 years old
This sounds like it could be the tensioner pulley is worn or needs a drop of oil, or the drum rollers need the same. If they are worn too much they will need replaced. If the tensioner pulley is stiff, replace the belt as well.
Jan 03, 2010 | Kenmore 62882 Electric Dryer
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 110.86874100 Motor (?) Squealing
I don't think they can be, but, also take a look at the fan bearing assembly too. You should be able to isolate if the noise is from the motor bearings or blower bearings.
Jan 26, 2009 | Dryers
Noisey dryer
Peace bumbabob,
Huuum t your service!
1-it may be the belt squealing or high pitched noises telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on! I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
3- I've seen also a few times that the motors heat shield, a simple piece if tin with two screws or bolts holding it down was "loose" and vibrating causing a loud metal squeal noise all the time or intermittently!!
If I were there hands on I could fix it!
Only a trained laundry tech can make the electronic diagnoses.
Unfortunately, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU
Sep 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 63942 Dryer Logo
352 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
